I've encountered a very puzzling issue with my WiFi card on Ubuntu. After reboot it's always disabled and there is no way to bring it back other than suspending or shutting down the laptop. Status according to Network Manager is "device not ready". This occurs consistently.
Some background on my system:
- The laptop is HP 350 G1.
- The WLAN card is the infamous Ralink RT3290. (If I knew how much trouble I would have with it I would never have bought it).
- Ubuntu is the latest LTS 16.04, recently upgraded.
- Kernel is
4.4.9-040409-generic(was4.4.0-22-genericbefore upgrading from mainline - no difference wrt WiFi).
Before upgrading the distro, I was using a version of the rt3290sta/2.6.0.0 driver (compiled from source and loaded via DKMS) which performed mostly fine, but it doesn't work with the newer kernels and it seems abandoned anyway. So now I had to revert to rt2800 and have this problem since.
This seems to be a very old but recurring issue. I read through all threads I could find, but so far no luck. Fortunately it's not critical for me because I rarely reboot, but it's still annoying and vexing at the least.
Below are outputs of some commands that could be of interest (this is the state after reboot):
lshw -c network says the interface is disabled:
# lshw -c network
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: eth0
version: 10
serial: c4:34:6b:05:5f:ff
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168g-3_0.0.1 04/23/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:43 ioport:4000(size=256) memory:b2504000-b2504fff memory:b2500000-b2503fff
*-network DISABLED
description: Wireless interface
product: RT3290 Wireless 802.11n 1T/1R PCIe
vendor: Ralink corp.
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlan0
version: 00
serial: 00:71:cc:6b:fe:f1
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rt2800pci driverversion=4.4.9-040409-generic firmware=0.37 latency=0 link=no multicast=yes wireless=IEEE 802.11bgn
resources: irq:17 memory:b2410000-b241ffff
*-network DISABLED
physical id: 1
logical name: virbr0-nic
serial: 52:54:00:e5:13:31
capabilities: ethernet physical
configuration: autonegotiation=off broadcast=yes driver=tun driverversion=1.6 duplex=full link=no multicast=yes port=twisted pair speed=10Mbit/s
However, rfkill list does not agree:
# rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
# iwconfig
virbr0-nic no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
virbr0 no wireless extensions.
lo no wireless extensions.
We can't bring it up though:
# ifconfig wlan0 up
SIOCSIFFLAGS: Input/output error
dmesg shows a couple of these errors:
# dmesg
[ 27.648857] ieee80211 phy0: rt2800_wait_wpdma_ready: Error - WPDMA TX/RX busy [0x00000068]
[ 29.248929] ieee80211 phy0: rt2800_wait_wpdma_ready: Error - WPDMA TX/RX busy [0x00000068]
[ 29.248936] ieee80211 phy0: rt2800pci_set_device_state: Error - Device failed to enter state 4 (-5)
Finally, part of syslog that looks relevant to me:
# cat /var/log/syslog | grep -i wlan
May 10 22:09:25 hp350g1 NetworkManager[820]: [1462910965.2639] devices added (path: /sys/devices/pci0000:00/0000:00:1c.1/0000:02:00.0/net/wlan0, iface: wlan0)
May 10 22:09:25 hp350g1 NetworkManager[820]: [1462910965.2639] device added (path: /sys/devices/pci0000:00/0000:00:1c.1/0000:02:00.0/net/wlan0, iface: wlan0): no ifupdown configuration found.
May 10 22:09:25 hp350g1 NetworkManager[820]: [1462910965.6626] (wlan0): using nl80211 for WiFi device control
May 10 22:09:25 hp350g1 NetworkManager[820]: [1462910965.6645] device (wlan0): driver supports Access Point (AP) mode
May 10 22:09:25 hp350g1 NetworkManager[820]: [1462910965.6813] manager: (wlan0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/0)
May 10 22:09:25 hp350g1 NetworkManager[820]: [1462910965.6882] device (wlan0): state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
May 10 22:09:25 hp350g1 kernel: [ 5.704724] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
May 10 22:09:29 hp350g1 NetworkManager[820]: [1462910969.0227] device (wlan0): supplicant interface state: init -> starting
May 10 22:09:32 hp350g1 wpa_supplicant[1339]: Could not set interface wlan0 flags (UP): Input/output error
May 10 22:09:32 hp350g1 wpa_supplicant[1339]: nl80211: Could not set interface 'wlan0' UP
May 10 22:09:32 hp350g1 wpa_supplicant[1339]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
May 10 22:09:35 hp350g1 wpa_supplicant[1339]: Could not set interface wlan0 flags (UP): Input/output error
May 10 22:09:35 hp350g1 wpa_supplicant[1339]: WEXT: Could not set interface 'wlan0' UP
May 10 22:09:35 hp350g1 wpa_supplicant[1339]: wlan0: Failed to initialize driver interface
May 10 22:09:35 hp350g1 NetworkManager[820]: [1462910975.4904] sup-iface[0x2450570,wlan0]: error adding interface: wpa_supplicant couldn't grab this interface.
May 10 22:09:35 hp350g1 NetworkManager[820]: [1462910975.4904] device (wlan0): supplicant interface state: starting -> down
May 10 22:09:46 hp350g1 NetworkManager[820]: [1462910986.0143] device (wlan0): re-acquiring supplicant interface (#1).
May 10 22:09:49 hp350g1 wpa_supplicant[1339]: Could not set interface wlan0 flags (UP): Input/output error
May 10 22:09:49 hp350g1 wpa_supplicant[1339]: nl80211: Could not set interface 'wlan0' UP
May 10 22:09:49 hp350g1 wpa_supplicant[1339]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
May 10 22:09:52 hp350g1 wpa_supplicant[1339]: Could not set interface wlan0 flags (UP): Input/output error
May 10 22:09:52 hp350g1 wpa_supplicant[1339]: WEXT: Could not set interface 'wlan0' UP
May 10 22:09:52 hp350g1 wpa_supplicant[1339]: wlan0: Failed to initialize driver interface
May 10 22:09:52 hp350g1 NetworkManager[820]: [1462910992.4485] sup-iface[0x24506d0,wlan0]: error adding interface: wpa_supplicant couldn't grab this interface.
... (after couple more tries)
May 10 22:11:00 hp350g1 NetworkManager[820]: [1462911060.4668] device (wlan0): supplicant interface state: starting -> down
May 10 22:11:00 hp350g1 NetworkManager[820]: [1462911060.4669] device (wlan0): supplicant interface keeps failing, giving up
