I have recently upgraded from Ubuntu 15.10 to 16.04. when i was using 15.10 ethernet works flawlessly. But after upgrading to 16.04 it doesn't work anymore showing network cable unplugged. I tried reinstalling driver & end up getting following error
sumit@Lenovo-Z50-70:~/Desktop/r8168-8.041.01$ sudo ./autorun.sh
[sudo] password for sumit:
Check old driver and unload it.
rmmod r8169
Build the module and install
make[2]: *** No rule to make target 'kernel/drivers/net/ethernet/realtek'.  Stop.
make[1]: *** [install] Error 2
make: *** [install] Error 2
When i had installed in 15.10 it was installed successfully. My ethernet controller is: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev10). I have done all proxy settings same as they were in 15.10.
Please help. :(
Get an internet connection(i got through wifi). Use the command:
sudo apt-get install r8168-dkms
Enter your password. This will install the latest version of the driver. Ethernet connection should be established after installing (you may reboot & check again).
For product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller the above solution didn't work. I had to download driver from here and install with ./autorun.sh.
After that I still couldn't connect to the internet. But the r8101 kernel module was loaded and in nm the connection came up. I noticed there was no mac address. With the following command I forced a random chosen mac address.
sudo ifconfig enp3s0 hw ether 00:04:FE:11:22:38
where enp3s0 was my ethernet nic. with this I got my internet connection but is wasn't persistent. I had to add
pre-up ifconfig enp3s0 hw ether 00:04:FE:11:22:38
at the end of /etc/network/interfaces file
sudo nano /etc/network/interfaces
Filip
  • 141
