I would like to do this by default tools and scripting. The logic is just to take pictures from the video and store them in the .gif format.
Editing
Do sudo apt-get install kazam pitivi openshot for test video. I record a video and get
  • I Choose Edit with Pitivi, and Press Continue. Fails. Bug here because of python3/gst-python dependency fails.
  • I choose Edit with Openshot, and Press Continue. GUI opens. Just drag the video to the bottom and add cuts. It works.
  • Avidemux not available in apt-get. I sent an email about the thing to the developer of Avidemux.
Conversion and Resizing
Do sudo apt-get install ffmpeg for the conversion tool.
Resize. If .mp4, downsample by 50%
# http://askubuntu.com/questions/160869/need-to-downsample-video-to-a-lower-resolution
ffmpeg -i input.mp4 -vf scale=iw/2:-1 output.mp4
Resize. If .gif, use the tool ezgif.com/resize because I could not find a one-liner for it. TODO
System: Ubuntu 16.04 64 bit, Debian 8.5
Hardware: Macbook Air 2013-mid, Asus Zenbook UX303UA
If by "default" you mean that you want to use integrated software, just printscreen frame by frame and then stich them together.
In GIMP, for the stich part, you need to open all the images as layers and then Filters > Animation > Playback... and modify them the options that you need.
dadexix86
  • 6,776
