12
I don't know if I am the only one with this bug, but I can't use my MSN account with a freshly installed Ubuntu 11.10 with Empathy. It used to work with my Arch Linux, but now with Ubuntu, it continuously tries to connect but nothing happens.
How can I solve this problem?
Yi Jiang
  • 1,206
aliasbody
  • 1,021
Without uninstalling anything, you can fix this by changing a line in the file /usr/share/pyshared/papyon/service/description/AB/__init__.py.
Edit it as root by running:
sudo -H gedit /usr/share/pyshared/papyon/service/description/AB/__init__.py
Change line 23 from this:
url = "http://contacts.msn.com/abservice/abservice.asmx"
To this:
url = "https://local-bay.contacts.msn.com/abservice/abservice.asmx"
Or to this:
url = "https://local-sn.contacts.msn.com/abservice/abservice.asmx"
Reboot and test it, it's working for me!
Eliah Kagan
  • 119,640
razor7
  • 1,589
Just open the terminal and enter this command:
sudo apt-get install msn-pecan
Then after it finishes installing, choose msn-pecan for your email instead of MSN messenger and it will work.
jokerdino
  • 41,732
sudo apt-get remove telepathy-butterfly
Remove your MSN account and add it again, it worked for me.
Yi Jiang
  • 1,206
Mazen
This happened on my PC at the weekend. I disabled the account, waited 10 seconds and then re-enabled the account. MSN network connected straight away.
Phil Hannent
  • 1,595
