Sending books from calibre to the M10 phablet connected to a laptop through an USB cable does not work out of the box.
- On the laptop, start calibre
- Plug the tablet to the laptop using a USB cable
- The M10 shows up in the file manager
Calibre detects the M10 and tries to writes the file driveinfo.calibre on the phablet, but fails with the folllowing error:
calibre, version 2.56.0 ERROR: Error: Error communicating with device Failed to upload file named: driveinfo.calibre to (u'frieza',): 2:PTP Layer error 2002: send_file_object_info(): Could not send object info. 2:Error 2002: PTP: General Error Traceback (most recent call last): File "site-packages/calibre/gui2/device.py", line 87, in run File "site-packages/calibre/gui2/device.py", line 503, in _books File "site-packages/calibre/devices/mtp/driver.py", line 216, in books File "site-packages/calibre/devices/mtp/driver.py", line 188, in get_driveinfo File "site-packages/calibre/devices/mtp/driver.py", line 178, in _update_drive_info File "site-packages/calibre/devices/mtp/driver.py", line 149, in put_calibre_file File "site-packages/calibre/devices/mtp/base.py", line 24, in synchronizer File "site-packages/calibre/devices/mtp/unix/driver.py", line 375, in put_file DeviceError: Failed to upload file named: driveinfo.calibre to (u'frieza',): 2:PTP Layer error 2002: send_file_object_info(): Could not send object info. 2:Error 2002: PTP: General Error
Meanwhile, trying to access the M10 files through the gnome file manager may or may not be successfull. (clicking on a folder can trigger an unknown libmtp error)
Running dmesg leads to:
[112904.984105] usb 2-1: new high-speed USB device number 29 using xhci_hcd
[112905.112763] usb 2-1: New USB device found, idVendor=2a47, idProduct=2008
[112905.112768] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[112905.112770] usb 2-1: Product: frieza
[112905.112771] usb 2-1: Manufacturer: Ubuntu
[112905.112772] usb 2-1: SerialNumber: ML003442
[112906.779195] usb 2-1: usbfs: process 8790 (DeviceManager) did not claim interface 0 before use
[112906.944292] usb 2-1: reset high-speed USB device number 29 using xhci_hcd
[112907.073082] usb 2-1: usbfs: process 8790 (DeviceManager) did not claim interface 0 before use
[112907.073123] usb 2-1: usbfs: process 9023 (events) did not claim interface 0 before use
In the end I cannot push books on the M10 for reading.
Anyone got the thing working?
