Today there was updates for my Ubuntu 16.04 (x64).
The updates were installed and it asked me to reboot.
After reboot I was unable to log into the graphic environment. It just looped to the login screen (Not the first time I have this problem)
After doing these steps:
service lightdm stop
sudo su -
cd /usr/local/bin
wget -Nc smxi.org/sgfxi
chmod +x sgfxi
sgfxi
I was able to login into graphic but I am stuck at 800 x 600. I was in 1080p before the update.
Please help.
Danibix
  • 2,185
TiriPon
  • 33
Just had a little similar issue. For some reason it was not blacklisting the nouveau drivers. Remember to install the nvidia drivers before doing this.
Try this:
cd /etc/modprobe.d
ls
Now look if there is an nvidia or nouveau file there, if not:
sudo nano /etc/modprobe.d/blacklist.conf
paste this at the bottom of the file:
blacklist vga16fb
blacklist nouveau
blacklist rivafb
blacklist nvidiafb
blacklist rivatv
Save with Ctrl+X and press Y to save.
Now run:
update-initramfs -u
sudo reboot
See if that works.
amc
  • 7,292
Joakim Koed
  • 2,782
I want to apologies in advance but this might not be accepted as an answer.
I was not able to fix that problem. I want to add that I got a similar issue when I upgraded from 15.04 to 15.10.
In both case I was unable to boot all the way to the GUI and ended up burning a DVD and re-installing from scratch.
When I install from scratch the resolution is correct and I can boot into the GUI using the Nvidia driver.
TiriPon
  • 33
