i want to see the access(times ,actions) of client to the RADIUS server, what's the command to view the the file log of RADIUS server plz
In *buntu: tail -f /var/log/freeradius/radius.log
Because the log contains information that should be kept secure, it is by default only readable by root.
You can also start the server in debug mode to get a lot more detail.
# freeradius -X
Before doing this, check to see if freeradius is already running (e.g. ps ax | fgrep freeradius). If it is running, stop it with service freeradius stop.
In debug mode with the -X switch, freeradius remains attached to the terminal so it can output detailed information via STDOUT on the terminal screen.
For extended detailed logging, you could nohup freeradius -X >/tmp/radius.log &.
Even more detailed logging is available with the -x and -xx switches.
