The idle CPU Temp of my Intel i5-3210M CPU was ~40°C on Ubuntu 14.04. Now, after upgrading to Ubuntu 16.04 (complete reinstall) it idles at ~52°C.
Battery lifetime is also noticeably lower.
What can I do? (What information is needed?)
I'm having the same problem. I ran the top command and the browser (vivaldi) is using the most cpu with up to 5 processes. The % range is between 1.5 to 7.0 without playing videos. The % range of the vivaldi browser playing videos is between 13.0 and 46.0. I'm not sure if has to do with ubuntu 16 or the vivaldi browser. I have no problems before with ubuntu 14.04.
I switched browsers (vivaldi, chromium, firefox) and the cpu's temperature incremented immediately within 90C.
I want to update this post. I couldn't find a solution running Ubuntu 16.04. I ended up reinstalling Ubuntu 14.04 and monitor the temperature. Firefox and Vivaldi still have problems raising the cpu temperature while playing videos. However, cpu temperature stays between 60's and 70's playing videos with Chromium. I watched around one hour of a video tutorial and the cpu temperature was stable. Looks like is a combination of OS and browser. The combination that works for me Ubuntu 14.04 and Chromium. Hope Canonical developers gets notify about the problem and fix it.
I had the same problem (after upgrade to 16.04 from 14.04). Psensors detected that my CPU's temperature is around 65° C. I look at the top, which showed me that psensors are using about 93% of CPU. Then I tried to run configure psensors again (see http://itsfoss.com/check-laptop-cpu-temperature-ubuntu/)
sudo sensors-detect
sensors
Now I am observing significant decrease of CPU temperature (from 40° to 45°).
My configuration: ThinkPad T440s, CPU : Intel(R) Core(TM) i5-4300U CPU @ 1.90GHz, OS: Ubuntu 16.04, Unity
The reason is because Ubuntu 16.04 does not use graphics. Now your CPU is doing all the heave lifting for the graphics. Sadly they won't allow you to use vendor graphics drivers anymore.
