I need more disk space at /tmp and /usr folders. How will achieve this?
An error appeared:
root@kali:/home/Downloads# ./netbeans-8.1-linux.sh
Configuring the installer...
Cannot create temporary directory /tmp/.nbi-5055107.tmp
Morpheus
  • 107
There's couple of ways you can go about this:
#1, remount /tmp with bigger size
As shown in Update failing. Not enough space on /tmp
sudo umount /tmp
sudo mount -t tmpfs -o size=16777216,mode=1777 overflow /tmp
That will give you 16 MB in/mpt . Adjust size= to how much you need
#2, make temporary directory in your home
$ mktemp -d -p $HOME
/home/xieerqi/tmp.zrBHbp0Yt0
That will make temporary directory in your $HOME folder, that means you can use as much space as you need
