I know there are similar questions already floating around the magical interweb, but I have quite a specific issue.
I built a new PC just yesterday, but decided not to go for an optical drive since I haven't used the one on my laptop in years. I figured the best way to install Windows then would be to boot Ubuntu from a flash drive, download Windows from there, and then install it onto the SSD. However, I encountered problems with the storage space on the flash drive(s) I was using, and accidentally ended up installing Ubuntu onto the SSD.
Now I have a bootable Windows OS on my flash drive, but cannot install it as the SSD is not formatted correctly. I assume I'm going to need to boot Ubuntu again, partition the SSD, and then install Windows from there? How do I do this? I'm tearing my hair out...
Gav
You don't need anything once you have bootable windows usb.
boot from your usb and then at this point during installation, detele all the partitions. This will give you a big unallocated space where you can install windows.
There is no need to care about partitioning tables (i.e GPT or MBR). Windows installation will take care of it.
Note: This image is just for showing the option of deleting a partition. Your actual partition size will be different. It will have a efi or system reserved partition (~ <= 500 MB) , a big ext4 partition and a swap partition (~ 4-10 GB).
You have to delete everything until you get a big unallocated space.
I could not find an exact image with ubuntu partitions.
Manoj
  • 941
  • 22
Run gparted, and format the drive to FAT32. If it's not installed, run apt-get install gparted from terminal. It will be accessible in the Ubuntu system tools menu or just by typing sudo gparted.
storm
  • 5,013
csv
