24
If I create a script and then place it in this folder (/etc/cron.hourly), will my system run this script hourly? Or does my script need to begin with a command as well?
Switchkick
  • 3,963
Every script placed in folder /etc/cron.hourly would run on hourly basis.
However your files needs to be:
  • executable,
  • match the Debian cron script namespace (^[a-zA-Z0-9_-]+$).
So for example if you've script with extension, it won't work.
To print the names of the scripts which would be invoked, run:
sudo run-parts --report --test /etc/cron.hourly
kenorb
  • 10,944
18
Yep, you got it.
Just start it with a #!/bin/bash like you normally would. And make sure you sudo chmod +x /etc/cron.hourly/yourscript because it won't run without execute permissions.
maco
  • 16,132
Anything in /etc/cron.hourly will be executed hourly, just like anything in /etc/cron.daily will be run once a day.
Make sure the file is executable, and start it with #!/bin/bash or #!/usr/bin/python (or #!/usr/bin/env python) or whatever is appropriate for the type of script you'll be running.
A.B.
  • 92,125
csgeek
  • 321
