17
I just updated a laptop to Ubuntu 16.04, and now I see the following problem. At random moments (but when some graphics activity is going on, such as opening a window), the display garbles and the computer freezes. The only thing one can do is to power it off forcefully; which of course loses any kernel log entries there may have been.
What can I do about this? dmesg (after a boot) lists a few ominous looking stack traces related to graphics:
[    2.220658] [drm] initialized overlay support
[    2.220751] [drm] Initialized i915 1.6.0 20151010 for 0000:00:02.0 on minor 0
[    2.240350] ------------[ cut here ]------------
[    2.240439] WARNING: CPU: 0 PID: 82 at /build/linux-Ay7j_C/linux-4.4.0/drivers/gpu/drm/i915/intel_display.c:1215
5 intel_atomic_check+0x2fd/0x6b0 [i915]()
[    2.240443] WARN_ON(!connector_state->crtc)
[    2.240446] Modules linked in:
[    2.240449]  ahci psmouse i915 firewire_ohci libahci b44 i2c_algo_bit pata_acpi drm_kms_helper ssb syscopyarea m
ii sysfillrect firewire_core sysimgblt fb_sys_fops crc_itu_t drm wmi fjes video
[    2.240477] CPU: 0 PID: 82 Comm: kworker/u4:3 Not tainted 4.4.0-21-generic #37-Ubuntu
[    2.240481] Hardware name: Hewlett-Packard HP Compaq nx7300 (RU460EA#ABH)/30A2, BIOS 68YGU Ver. F.0C 07/25/2007
[    2.240489] Workqueue: events_unbound async_run_entry_fn
[    2.240492]  0000000000000286 000000003c6593a8 ffff880035ae39a0 ffffffff813e93c3
[    2.240498]  ffff880035ae39e8 ffffffffc0215a50 ffff880035ae39d8 ffffffff81080f62
[    2.240503]  ffff880034e08800 ffff880034e0a800 ffff880034e08800 0000000000000000
[    2.240508] Call Trace:
[    2.240516]  [<ffffffff813e93c3>] dump_stack+0x63/0x90
[    2.240522]  [<ffffffff81080f62>] warn_slowpath_common+0x82/0xc0
[    2.240526]  [<ffffffff81080ffc>] warn_slowpath_fmt+0x5c/0x80
[    2.240569]  [<ffffffffc0045f9d>] ? drm_atomic_add_affected_planes+0x7d/0xd0 [drm]
[    2.240628]  [<ffffffffc01b356d>] intel_atomic_check+0x2fd/0x6b0 [i915]
[    2.240657]  [<ffffffffc004680e>] drm_atomic_check_only+0x18e/0x590 [drm]
[    2.240686]  [<ffffffffc0046cfd>] ? drm_atomic_set_fb_for_plane+0x2d/0x90 [drm]
[    2.240715]  [<ffffffffc0046c27>] drm_atomic_commit+0x17/0x60 [drm]
[    2.240773]  [<ffffffffc01b71e5>] intel_get_load_detect_pipe+0x3d5/0x530 [i915]
[    2.240833]  [<ffffffffc01f08ed>] intel_tv_detect+0x13d/0x5f0 [i915]
[    2.240861]  [<ffffffffc00412de>] ? drm_get_edid+0x3e/0x3f0 [drm]
[    2.240884]  [<ffffffffc00d9da5>] drm_helper_probe_single_connector_modes_merge_bits+0x235/0x4d0 [drm_kms_helper]
[    2.240896]  [<ffffffffc00da053>] drm_helper_probe_single_connector_modes+0x13/0x20 [drm_kms_helper]
[    2.240910]  [<ffffffffc00e691e>] drm_fb_helper_initial_config+0xae/0x420 [drm_kms_helper]
[    2.240967]  [<ffffffffc01c74bb>] intel_fbdev_initial_config+0x1b/0x20 [i915]
[    2.240972]  [<ffffffff810a2f28>] async_run_entry_fn+0x48/0x150
[    2.240977]  [<ffffffff81099ff2>] process_one_work+0x162/0x480
[    2.240981]  [<ffffffff8109a35b>] worker_thread+0x4b/0x4c0
[    2.240986]  [<ffffffff8109a310>] ? process_one_work+0x480/0x480
[    2.240990]  [<ffffffff810a0528>] kthread+0xd8/0xf0
[    2.240994]  [<ffffffff810a0450>] ? kthread_create_on_node+0x1e0/0x1e0
[    2.241000]  [<ffffffff8182488f>] ret_from_fork+0x3f/0x70
[    2.241004]  [<ffffffff810a0450>] ? kthread_create_on_node+0x1e0/0x1e0
[    2.241008] ---[ end trace 9c3f9641e06cab07 ]---
[    2.241013] ------------[ cut here ]------------
[    2.241072] WARNING: CPU: 0 PID: 82 at /build/linux-Ay7j_C/linux-4.4.0/drivers/gpu/drm/i915/intel_display.c:11693 intel_plane_atomic_calc_changes+0x567/0x6c0 [i915]()
[    2.241075] WARN_ON(was_visible)
[    2.241077] Modules linked in:
[    2.241079]  ahci psmouse i915 firewire_ohci libahci b44 i2c_algo_bit pata_acpi drm_kms_helper ssb syscopyarea mii sysfillrect firewire_core sysimgblt fb_sys_fops crc_itu_t drm wmi fjes video
[    2.241103] CPU: 0 PID: 82 Comm: kworker/u4:3 Tainted: G        W       4.4.0-21-generic #37-Ubuntu
[    2.241106] Hardware name: Hewlett-Packard HP Compaq nx7300 (RU460EA#ABH)/30A2, BIOS 68YGU Ver. F.0C 07/25/2007
[    2.241111] Workqueue: events_unbound async_run_entry_fn
[    2.241114]  0000000000000286 000000003c6593a8 ffff880035ae3888 ffffffff813e93c3
[    2.241119]  ffff880035ae38d0 ffffffffc0215a50 ffff880035ae38c0 ffffffff81080f62
[    2.241124]  0000000000000001 ffff8800356ed000 ffff880034da9540 ffff88003545f800
[    2.241129] Call Trace:
[    2.241133]  [<ffffffff813e93c3>] dump_stack+0x63/0x90
[    2.241137]  [<ffffffff81080f62>] warn_slowpath_common+0x82/0xc0
[    2.241141]  [<ffffffff81080ffc>] warn_slowpath_fmt+0x5c/0x80
[    2.241199]  [<ffffffffc01b8e87>] intel_plane_atomic_calc_changes+0x567/0x6c0 [i915]
[    2.241211]  [<ffffffffc00da33b>] ? drm_plane_helper_check_update+0xdb/0x190 [drm_kms_helper]
[    2.241268]  [<ffffffffc01991d0>] intel_plane_atomic_check+0x140/0x1f0 [i915]
[    2.241281]  [<ffffffffc00e1a68>] drm_atomic_helper_check_planes+0x48/0x1c0 [drm_kms_helper]
[    2.241339]  [<ffffffffc01b3400>] intel_atomic_check+0x190/0x6b0 [i915]
[    2.241367]  [<ffffffffc004680e>] drm_atomic_check_only+0x18e/0x590 [drm]
[    2.241396]  [<ffffffffc0046cfd>] ? drm_atomic_set_fb_for_plane+0x2d/0x90 [drm]
[    2.241425]  [<ffffffffc0046c27>] drm_atomic_commit+0x17/0x60 [drm]
[    2.241482]  [<ffffffffc01b71e5>] intel_get_load_detect_pipe+0x3d5/0x530 [i915]
[    2.241542]  [<ffffffffc01f08ed>] intel_tv_detect+0x13d/0x5f0 [i915]
[    2.241571]  [<ffffffffc00412de>] ? drm_get_edid+0x3e/0x3f0 [drm]
[    2.241583]  [<ffffffffc00d9da5>] drm_helper_probe_single_connector_modes_merge_bits+0x235/0x4d0 [drm_kms_helper]
[    2.241595]  [<ffffffffc00da053>] drm_helper_probe_single_connector_modes+0x13/0x20 [drm_kms_helper]
[    2.241608]  [<ffffffffc00e691e>] drm_fb_helper_initial_config+0xae/0x420 [drm_kms_helper]
[    2.241666]  [<ffffffffc01c74bb>] intel_fbdev_initial_config+0x1b/0x20 [i915]
[    2.241671]  [<ffffffff810a2f28>] async_run_entry_fn+0x48/0x150
[    2.241675]  [<ffffffff81099ff2>] process_one_work+0x162/0x480
[    2.241679]  [<ffffffff8109a35b>] worker_thread+0x4b/0x4c0
[    2.241683]  [<ffffffff8109a310>] ? process_one_work+0x480/0x480
[    2.241687]  [<ffffffff810a0528>] kthread+0xd8/0xf0
[    2.241691]  [<ffffffff810a0450>] ? kthread_create_on_node+0x1e0/0x1e0
[    2.241695]  [<ffffffff8182488f>] ret_from_fork+0x3f/0x70
[    2.241699]  [<ffffffff810a0450>] ? kthread_create_on_node+0x1e0/0x1e0
[    2.241702] ---[ end trace 9c3f9641e06cab08 ]---
[    2.352069] ------------[ cut here ]------------
[    2.352171] WARNING: CPU: 0 PID: 82 at /build/linux-Ay7j_C/linux-4.4.0/drivers/gpu/drm/i915/intel_display.c:12732 intel_modeset_check_state+0x563/0x8a0 [i915]()
[    2.352176] encoder's enabled state mismatch (expected 0, found 1)
[    2.352179] Modules linked in: ahci psmouse i915 firewire_ohci libahci b44 i2c_algo_bit pata_acpi drm_kms_helper ssb syscopyarea mii sysfillrect firewire_core sysimgblt fb_sys_fops crc_itu_t drm wmi fjes video
[    2.352221] CPU: 0 PID: 82 Comm: kworker/u4:3 Tainted: G        W       4.4.0-21-generic #37-Ubuntu
[    2.352225] Hardware name: Hewlett-Packard HP Compaq nx7300 (RU460EA#ABH)/30A2, BIOS 68YGU Ver. F.0C 07/25/2007
[    2.352235] Workqueue: events_unbound async_run_entry_fn
[    2.352240]  0000000000000286 000000003c6593a8 ffff880035ae3960 ffffffff813e93c3
[    2.352248]  ffff880035ae39a8 ffffffffc0215a50 ffff880035ae3998 ffffffff81080f62
[    2.352254]  ffff880034e08b18 ffff880035589600 ffff880034e08b48 ffff880034e08b30
[    2.352261] Call Trace:
[    2.352272]  [<ffffffff813e93c3>] dump_stack+0x63/0x90
[    2.352279]  [<ffffffff81080f62>] warn_slowpath_common+0x82/0xc0
[    2.352285]  [<ffffffff81080ffc>] warn_slowpath_fmt+0x5c/0x80
[    2.352347]  [<ffffffffc01ef9f7>] ? intel_tv_get_hw_state+0x27/0x50 [i915]
[    2.352394]  [<ffffffffc01a6433>] intel_modeset_check_state+0x563/0x8a0 [i915]
[    2.352440]  [<ffffffffc01b1bcb>] intel_atomic_commit+0x4bb/0x6f0 [i915]
[    2.352472]  [<ffffffffc0046c47>] drm_atomic_commit+0x37/0x60 [drm]
[    2.352518]  [<ffffffffc01b71e5>] intel_get_load_detect_pipe+0x3d5/0x530 [i915]
[    2.352566]  [<ffffffffc01f08ed>] intel_tv_detect+0x13d/0x5f0 [i915]
[    2.352589]  [<ffffffffc00412de>] ? drm_get_edid+0x3e/0x3f0 [drm]
[    2.352606]  [<ffffffffc00d9da5>] drm_helper_probe_single_connector_modes_merge_bits+0x235/0x4d0 [drm_kms_helper]
[    2.352615]  [<ffffffffc00da053>] drm_helper_probe_single_connector_modes+0x13/0x20 [drm_kms_helper]
[    2.352626]  [<ffffffffc00e691e>] drm_fb_helper_initial_config+0xae/0x420 [drm_kms_helper]
[    2.352672]  [<ffffffffc01c74bb>] intel_fbdev_initial_config+0x1b/0x20 [i915]
[    2.352676]  [<ffffffff810a2f28>] async_run_entry_fn+0x48/0x150
[    2.352680]  [<ffffffff81099ff2>] process_one_work+0x162/0x480
[    2.352683]  [<ffffffff8109a35b>] worker_thread+0x4b/0x4c0
[    2.352687]  [<ffffffff8109a310>] ? process_one_work+0x480/0x480
[    2.352690]  [<ffffffff810a0528>] kthread+0xd8/0xf0
[    2.352693]  [<ffffffff810a0450>] ? kthread_create_on_node+0x1e0/0x1e0
[    2.352698]  [<ffffffff8182488f>] ret_from_fork+0x3f/0x70
[    2.352701]  [<ffffffff810a0450>] ? kthread_create_on_node+0x1e0/0x1e0
[    2.352704] ---[ end trace 9c3f9641e06cab09 ]---
[    2.380278] firewire_core 0000:02:06.1: created device fw0: GUID 00023f9929c9140e, S400
[    2.424067] ------------[ cut here ]------------
[    2.424151] WARNING: CPU: 0 PID: 82 at /build/linux-Ay7j_C/linux-4.4.0/drivers/gpu/drm/i915/intel_display.c:12155 intel_atomic_check+0x2fd/0x6b0 [i915]()
[    2.424156] WARN_ON(!connector_state->crtc)
[    2.424159] Modules linked in:
[    2.424163]  ahci psmouse i915 firewire_ohci libahci b44 i2c_algo_bit pata_acpi drm_kms_helper ssb syscopyarea mii sysfillrect firewire_core sysimgblt fb_sys_fops crc_itu_t drm wmi fjes video
[    2.424196] CPU: 0 PID: 82 Comm: kworker/u4:3 Tainted: G        W       4.4.0-21-generic #37-Ubuntu
[    2.424201] Hardware name: Hewlett-Packard HP Compaq nx7300 (RU460EA#ABH)/30A2, BIOS 68YGU Ver. F.0C 07/25/2007
[    2.424208] Workqueue: events_unbound async_run_entry_fn
[    2.424213]  0000000000000286 000000003c6593a8 ffff880035ae39e8 ffffffff813e93c3
[    2.424220]  ffff880035ae3a30 ffffffffc0215a50 ffff880035ae3a20 ffffffff81080f62
[    2.424227]  ffff880034e08800 ffff880034e0a800 ffff880034e08800 0000000000000000
[    2.424234] Call Trace:
[    2.424241]  [<ffffffff813e93c3>] dump_stack+0x63/0x90
[    2.424248]  [<ffffffff81080f62>] warn_slowpath_common+0x82/0xc0
[    2.424253]  [<ffffffff81080ffc>] warn_slowpath_fmt+0x5c/0x80
[    2.424261]  [<ffffffff811eebf4>] ? __kmalloc_track_caller+0x1b4/0x250
[    2.424330]  [<ffffffffc01b356d>] intel_atomic_check+0x2fd/0x6b0 [i915]
[    2.424356]  [<ffffffffc004680e>] drm_atomic_check_only+0x18e/0x590 [drm]
[    2.424380]  [<ffffffffc0046cf0>] ? drm_atomic_set_fb_for_plane+0x20/0x90 [drm]
[    2.424402]  [<ffffffffc0046c27>] drm_atomic_commit+0x17/0x60 [drm]
[    2.424449]  [<ffffffffc01b7460>] intel_release_load_detect_pipe+0x120/0x160 [i915]
[    2.424497]  [<ffffffffc01f0aeb>] intel_tv_detect+0x33b/0x5f0 [i915]
[    2.424508]  [<ffffffffc00d9da5>] drm_helper_probe_single_connector_modes_merge_bits+0x235/0x4d0 [drm_kms_helper]
[    2.424517]  [<ffffffffc00da053>] drm_helper_probe_single_connector_modes+0x13/0x20 [drm_kms_helper]
[    2.424528]  [<ffffffffc00e691e>] drm_fb_helper_initial_config+0xae/0x420 [drm_kms_helper]
[    2.424575]  [<ffffffffc01c74bb>] intel_fbdev_initial_config+0x1b/0x20 [i915]
[    2.424578]  [<ffffffff810a2f28>] async_run_entry_fn+0x48/0x150
[    2.424582]  [<ffffffff81099ff2>] process_one_work+0x162/0x480
[    2.424585]  [<ffffffff8109a35b>] worker_thread+0x4b/0x4c0
[    2.424588]  [<ffffffff8109a310>] ? process_one_work+0x480/0x480
[    2.424591]  [<ffffffff810a0528>] kthread+0xd8/0xf0
[    2.424595]  [<ffffffff810a0450>] ? kthread_create_on_node+0x1e0/0x1e0
[    2.424599]  [<ffffffff8182488f>] ret_from_fork+0x3f/0x70
[    2.424602]  [<ffffffff810a0450>] ? kthread_create_on_node+0x1e0/0x1e0
[    2.424605] ---[ end trace 9c3f9641e06cab0a ]---
and some more (but they seem quite similar).
Typing lshw -c video I get this:
$ sudo lshw -c video
*-display:0
       description: VGA compatible controller
       product: Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 03
       width: 32 bits
       clock: 33MHz
       capabilities: msi pm vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:16 memory:f4400000-f447ffff ioport:4000(size=8) memory:e0000000-efffffff memory:f4480000-f44bffff
*-display:1 UNCLAIMED
       description: Display controller
       product: Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller
       physical id: 2.1
       bus info: pci@0000:00:02.1
       version: 03
       width: 32 bits
       clock: 33MHz
       capabilities: pm bus_master cap_list
       configuration: latency=0
       resources: memory:f4500000-f457ffff
Reinstalling the X drivers, as in 16.04 - How To Purge Intel Default Drivers & Reinstall Intel Graphic Drivers didn't help. Under previous Ubuntu versions, this problem did not exist although some 3D operations (such as the rotating desktop cube) didn't quite do the perspective transformations right.
This worked for me:
  1. open software & updates
  2. Go to additional Driver
  3. select intel graphics
  4. Restart your pc/laptop
David Foerster
  • 36,890
  • 56
  • 97
  • 151
