I've recently bumped into this problem. I usually navigate through a local network shared folder from a Linux machine via smb (i.e. from file manger using smb: ). Now whenever I try to access the shortcut or typing credential again I keep getting the dialog window asking for user, domain and password.
So I tried mounting the location manually using cisf-utils doing:
sudo mount -t cifs //fileshare1/docs1/user/My\ Documents/shared/Francesco/ /home/frank/used_shared/ -o username=my_user,password=my_pass,domain=my_domain,gid=1000,uid=1000
I get mount error(13): Permission denied.
I'm definitely sure my user has permission on that folder cause I can access it from a windows machine.
Also if I try to mount my personal folder on that location through:
sudo mount -t cifs //fileshare1/docs5/francesco.azzarello/ /home/frank/mnt_folder -o username=my_user,password=my_pass,domain=my_domain,gid=1000,uid=1000
I can access it with no problem.
For reference I'm using 4.2.0-36-generic kernel and my mount.cifs version is 6.4
Any idea on how to make one of both methods work?
Update Rgarding ponsfrilus answer
number 1: verbose option returns:
_mount.cifs kernel mount options: ip=xxx.xxx.xxx.xxx,unc=\\fileshare1\docs1,uid=1000,gid=1000,user=my_user,,domain=my_domain,prefixpath=user/My Documents/shared/Francesco/,pass=********
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)_
Number 2 is basically the same thing:
_ mount.cifs kernel mount options: ip=xxx.xxx.xxx.xxx,unc=\\fileshare1\docs1,iocharset=utf8,file_mode=0777,dir_mode=0777,user=my_user,,domain=my_domain,prefixpath=user/My Documents/shared/Francesco/,pass=********
And nothing changed with vers=2.1:
_mount.cifs kernel mount options: ip=xxx.xxx.xxx.xxx,unc=\\fileshare1\docs1,vers=2.1,iocharset=utf8,file_mode=0777,dir_mode=0777,user=my_user,,domain=my_domain,prefixpath=user/My Documents/shared/Francesco/,pass=********
As for number 4 I can mount docs1 no problem but I can navigate tho get to the shared folder in user.
