What happened
I was working on my laptop while it upgraded from 15.10 to 16.04 (which I admit was a mistake) when suddenly the Unity overlay disappeared and the only thing on screen was the Firefox browser window. I switched to a new terminal, logged in and tried to run sudo service lightdm restart but instead of restarting correctly, the screen started turning on and off repeatedly, which freaked me out, so I physically turned off the PC.
Long story short: I forced a shutdown halfway through the Ubuntu upgrade.
Ever since, any attempts of logging in normally have been met with a solid black screen and the idle whirring of the CPU fan.
What I have tried
I have tried the recovery mode boot up, but no luck (The log does greet "Welcome to Ubuntu 16.04 LTS!"). I tried out each option that seemed useful:
  • dpkg goes through the packages as advertised, but strangely enough it always locks up on some Braille package until I do Ctrl+C, at which moment it spouts some error messages and then I think throws me into the normal boot.
  • failsafeX results in a similar situation to the normal boot: a black void.
  • fsck says the single partition I have is a-ok.
  • grub seems to get a bunch of stuff. Don't know if it searches locally or fetches from the internet.
  • network didn't work I think.
I tried following this answer but couldn't do the sudo part because the filesystem was mounted as readonly. So I ran fsck which mounts as RW and tried again.
This time, after running apt-get autoremove it went through many packages (Setting up foobar (X.Y.ZubuntuN) ...), sometimes installing packages, which I assume is the usual behavior. One thing to note though is it kept getting stuck several times, so I had to Ctrl+C it out of processing the current package. It finally ended on "Processing was halted because there were too many errors.".
While this question seems to mention some of the graphics problems I've been experiencing... I have Intel HD Graphics, not Nvidia. I'll keep looking into it.
One solution, maybe not the best, but one I would try, is to just reinstall over your broken system, without removing your personal files.
Get your hands on a fresh 16.04 Installation Medium (not the old version) and prepare your computer. Making a backup of your /home folder is always a good idea.
You can take a look at this link for more information on how to do this properly.
The basics are this:
  1. Install Ubuntu like you usually would.
  2. When choosing the installation type, try a "install over" or "upgrade" option. The description of the option should say something like "Documents, Music, and other personal files will be kept..."
  3. Install the system as usual.
The key part about this is to not format the home folder. If you have a separate partition for /home, don't format it. If you don't have a separate partition, don't format /, but select it as the root installation location.
Benefits of this method?
  • Easy
  • Reliable
  • Almost guarenteed to work
  • You will keep all your files and preferences in your home folder
The downsides?
  • You lose your installed applications (you'll have to reinstall them)
  • Application settings or configurations that aren't found in your home folder will be reset (most applications put settings somewhere in /home, so this will only be the case for a few applications)
  • Might take a while depending on the speed of your computer
You can use the Live-DVD/USB to fix your system.
Boot the Ubuntu Live-DVD/USB.
Open a terminal,
Press Ctrl+Alt+T
Type the following:
exec sudo -i
Use the fdisk utility to list the partitions on a device.
Type the following:
fdisk -l
suppose fdisk informed that / is /dev/sda1
Type the following:
mount /dev/sda1 /mnt
mount --bind /dev /mnt/dev
mount --bind /dev/pts /mnt/dev/pts
mount --bind /proc /mnt/proc
mount --bind /sys /mnt/sys
chroot /mnt
nano /etc/resolv.conf
Add OpenDNS name servers to /etc/resolv.conf file:
nameserver 208.67.222.222
nameserver 208.67.220.220
Ctrl+O Save file.
Ctrl+X Close nano.
Now type the following:
apt-get update
apt-get -f install
apt-get dist-upgrade
apt-get autoremove
dpkg --configure -a
apt-get clean
umount /dev/sda1
reboot
Note: change /dev/sda1 for your / partition
kyodake
  • 17,808
In the end, doing apt-get autoremove on the RW filesystem and then rebooting seems to have fixed enough so that I could log in graphically again (albeit without Unity components showing up, but that was a different problem). I'll leave the question up, even if it's messy and goes into tangents, in case it might help anyone with a similar problem.
Thanks to Zach and kyodake for their helpful answers, but thankfully I didn't have to resort to reinstalling the OS or using the Live CD tools... this time.
