115
When I run the command:
sudo apt-get update
I got this following warning:
There is no public key available for the following key IDs: 1397BC53640DB551
This is the only warning I got and I do not get any Error.
How I can fix it and what the key 1397BC53640DB551 is all about?
muru
  • 207,228
Marcellinov
  • 3,389
  • 16
  • 23
I resolved running:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 1397BC53640DB551
The command above download the missing key using the hexadecimal numbers given in the error (1397BC53640DB551) with apt-key. After running apt-key to download the missing PUBKEY, any packages from that repositories will be considered trusted.
It seems to be a known problem in chromium that is being worked on (check here). They are working to remove SHA1 encryption (link).
Another possible workarounds that have been posted on reddit
wget -q -O - https://dl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
Looking at this, seems that Google now has two keys, and the old one will probably be discontinued along with SHA1.
Marcellinov
  • 3,389
  • 16
  • 23
46
Correct command line is:
Marcellinov
  • 3,389
  • 16
  • 23
iFred
  • 560
