I would like to know if Ubuntu can be installed on a new server HP with this characteristics:
HP Part number: 755262-B21
Specifications: HP ProLiant DL360p Gen9, Intel® Xeon® E5-2630v3 (2.4GHz/8-core/20MB/85W), 16GB (1x16GB), HP Embedded 1Gb Ethernet 4-port 331i Adapter, HP Flexible Smart Array P440ar/2GB (RAID 0, 1, 10, 5, 6), 8 SFF HDD Bays, Optional via Universal Media Bay, 2 Standard (1-FH/¾ L, 1-LP) PCIe 3.0, (1) HP 500W Flex Slot Platinum Power Supply, 5 Standard hot plug fans, redundant, iLO Management (standard), Intelligent Provisioning (standard).
Thanks in advance
Victor David Nasser
Yes, but only with the Smart Array disabled. According to the Ubuntu Hardware Certification Program:
The HP ProLiant DL360 Gen9 rack mount chassis with the components described below has been awarded the status of certified for Ubuntu.
Ubuntu 16.04 LTS 64-bit
This system was tested with 16.04 LTS, running the 4.4.0-15.31 kernel.
Certification notes
HP Dynamic Smart Array
System is certified with Dynamic Smart Array disabled.
To disable Dynamic Smart Array:
  • Press F9 to boot into RBSU
  • Navigate to System Options -> HP Dynamic Smart Array B320i and select disable
  • Go to System options -> SATA Controller options and select Legacy SATA or AHCI
  • Reboot the machine and now you will be able to install the OS.
Pre-Release Testing
This system was tested with a Pre-Release version of Ubuntu.
This certification is considered valid only for 60 days after this Ubuntu Release and must be re-tested with the GA release of Ubuntu to be considered permanently certified.
BIOS
  • HP: P89 (UEFI)
Ubuntu 14.04.1 LTS 64-bit
This system was tested with 14.04 LTS, running the 3.13.0-35.62 kernel.
Certification notes
HP ILO and MAAS
  • ILO firmware version 2.30 will not work with MAAS. To use this system in a MAAS environment you will need to update to the latest ILO firmware (greater than version 2.30).
  • If you are using ILO 2.20 or older, you are not affected by this issue. Please refer to HP for more information on updating ILO firmware.
BIOS
  • HP: P89 (UEFI)
This information can be viewed at http://www.ubuntu.com/certification/hardware/201409-15509/
