First you need to make sure each line/part of your bash script work in a shell (outside of a script). I cannot tell if yours will so you'll have to check that yourself.
And to execute a python script you need python BEFORE the path to the script
Also:
~ is a shortcut to the home directory of the current user
~asdf is a shortcut to the home directory for the asdf user
~/Documents is the path to the Documents folder in the home directory of the current user
~Documents is looking for the home directory of the Directory user which is invalid unless you have a user called Directory
As @muru pointed out, you probably meant ~/Documents. So your bash script would probably look something like this
#!/bin/bash
python ~/Documents/dota2/dotaapi2/match_scraper.py
psql dota2apidb
update games set online=1 where online is null;
python ~/Documents/dota2/gosugamers/gosugamers/spiders/scrapy crawl dota
Again, I do not know if this will work since I have no clue if each line will work. For example, does python ~/Documents/dota2/gosugamers/gosugamers/spiders/scrapy crawl dota actually work when you run it on the command line?
And I do not know psql but I suspect you need to pass it some command line paramater to get it to run that update... command?
