I have recently upgraded my ubuntu to 15.10 and eventually Ethernet names were changed. I don't have any problem with the names but whenever I reboot the system the Ethernet connectivity is lost. The problem is the that the Ethernet device doesn't come up itself so I have to manually run the command.
ip link set ens255f0 up.
In /etc/network/interfaces file, I put
auto ens255f0
iface ens255f0 inet dhcp
but it didn't help. Could anybody help how can I solve this problem?
P.S: This is not duplicate question to this as there is no mention of this issue. Network interface name changes after update to 15.10 - udev changes
slal
I know this is old, just had the same problem myself, after install if you had no network plugged in it defaults the NIC to down after every restart.
/etc/netplan/00-installer-config.yaml replace eno1 with NIC tag, for example: ens255f0
network:
  ethernets:
    eno1:
      dhcp4: true
    eno2:
      dhcp4: true
  version: 2
reboot after done, this fixed two servers I had installed OS off network.
TommyD
Edit rc.local file
sudo nano /etc/rc.local
Add below lines above exit 0:
ifdown ens255f0
sleep 3
ifup ens255f0
Reboot
