I have done nothing. Just normally uses my 15.10 Willy. But after the last shutdown at 1 pm I couldn't get pass the loading screen. There is very important things in my laptop. Anyway to recover this position? Please help me I mean it
Asked
Active
Viewed 63 times
It's very hard to tell anything without knowing the output. You can try choosing older kernel (maybe kernel update caused this), by selecting "Advanced options for Ubuntu" in Grub menu at the beginning (if Grub menu doesn't appear, hold Shift while booting).
Much better will be access kernel boot options by pressing "e" and remove "splash" and the "quiet" entries from the boot parameters to make Ubuntu display the output during boot and read what the error is. To get logs of this, you need to access your hard drive from LiveCD or LiveUSB and take logs from /var/log, e.g.:
/var/log/boot.log
/var/log/dmesg
Using LiveUSB, You can also rescue your data to another computer.
There is a lot of questions on Ubuntu boot, so knowing the output, you can google for your error.
Slowpoke
- 218
