I've installed Ubuntu 16.04 LTS. During the installation, I've checked 'encrypted home' but home folder is in the same partition as the root (i.e in '/'). I know that the usage of TRIM on LUKS devices is different but I could not find anything about how to use it in my case. I also know that the installer uses ecryptfs for home folder encryption. The only thing I could found is this link TRIM and encrypted home folders, but it does not provide an answer. So the question is: How can I use TRIM on my encrypted home folder (not partition)? Several info you might need:
SSD: Corsair Force LS SSD
~$ lsblk
NAME           MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINT
sda              8:0    0 223.6G  0 disk
├─sda1           8:1    0   512M  0 part  /boot/efi
├─sda2           8:2    0 215.2G  0 part  /
└─sda3           8:3    0   7.9G  0 part
  └─cryptswap1 252:0    0   7.9G  0 crypt [SWAP]
~$ uname -r
4.4.0-21-generic
kmotoko
  • 148
Encrypted home folder are virtualy mounted unencrypted.
All your files in your encrypted /home/username folder exist real in:/home/.ecryptfs/username in encrypted format.
So if you use "fstrim -av" you are trimming the complete disk unneeded.
~$ fstrim -av
/home/username: 271.1 GiB (291104260096 bytes) trimmed
/: 0 B (0 bytes) trimmed
After every reboot it will do the same.
So it is better to trimm only the real files written on disk:
fstrim -v /
Add a weekly scheduler:
sudo cp /usr/share/doc/util-linux/examples/fstrim.{service,timer} /etc/systemd/system
sudo systemctl enable fstrim.timer
and edit /etc/systemd/system/fstrim.service
[Unit]
Description=Discard unused blocks
[Service]
Type=oneshot
ExecStart=/sbin/fstrim -v /
