Since this .deb bug is causing a lot of issues, I must resort to install the Opera browser using the terminal. Which is just fine, but I also need to add it to the repository for automatic updates.
Since I am no expert at all, I do not know how to perform the full installation of the browser. How do I go about it?
Thanks!
P.S. Please do not mark this as duplicate, because the other posts dont details how to go about installing Opera with adding it to the repository too for updates. Cheers.
Elysium
  • 11,142
To install opera via PPA on Ubuntu, run these commands
Setup key with:
wget -O - http://deb.opera.com/archive.key | sudo apt-key add -
Setup repository with:
sudo sh -c 'echo "deb http://deb.opera.com/opera-stable/ stable non-free" >> /etc/apt/sources.list.d/opera.list'
Setup package with:
sudo apt-get update
sudo apt-get install opera
Source
Alternatively, you can install the .deb via a terminal with
sudo dpkg -i path/to/your/deb
It already contains the PPA, if anyone else reading this is still facing the .deb issue with gnome-software, please report it here, it is supposed to be fixed.
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
