I upgraded a KUbuntu 14.04 LTS install to xorg-core-lts-wily and all its dependencies, in order to be able to run on a 6th gen i3 with a HD520 graphics.
That meant I lost wine, and I cannot seem to get it reinstalled. Even when following the instructions at Wine installation isue after upgrade 12.04 -> 14.04 (= using the ubuntu-wine/ppa PPA) I still get the following:
> env LC_ALL=C sudo aptitude -s install wine1.8
The following NEW packages will be installed:
  fonts-horai-umefont{a} libasn1-8-heimdal:i386{a} libasound2:i386{a} libasound2-plugins:i386{a} libasyncns0:i386{a}
  libavahi-client3:i386{a} libavahi-common-data:i386{a} libavahi-common3:i386{a} libcapi20-3{a} libcapi20-3:i386{a}
  libcups2:i386{a} libdrm-amdgpu1:i386{a} libdrm-intel1:i386{a} libdrm-nouveau2:i386{a} libdrm-radeon1:i386{a} libedit2:i386{a}
  libelf1:i386{a} libexif12:i386{a} libflac8:i386{a} libgcrypt11:i386{a} libgd3:i386{a} libgif4:i386{a}
  libgl1-mesa-dri-lts-wily:i386{a} libgl1-mesa-glx-lts-wily:i386{a} libglapi-mesa-lts-wily:i386{a} libglu1-mesa:i386{a}
  libgnutls26:i386{a} libgpg-error0:i386{a} libgphoto2-6:i386{a} libgphoto2-port10:i386{a} libgssapi-krb5-2:i386{a}
  libgssapi3-heimdal:i386{a} libgstreamer-plugins-base0.10-0:i386{a} libgstreamer0.10-0:i386{a} libhcrypto4-heimdal:i386{a}
  libheimbase1-heimdal:i386{a} libheimntlm0-heimdal:i386{a} libhx509-5-heimdal:i386{a} libieee1284-3:i386{a}
  libjack-jackd2-0:i386{a} libjbig0:i386{a} libjpeg-turbo8:i386{a} libjpeg8:i386{a} libk5crypto3:i386{a} libkeyutils1:i386{a}
  libkrb5-26-heimdal:i386{a} libkrb5-3:i386{a} libkrb5support0:i386{a} liblcms2-2:i386{a} libldap-2.4-2:i386{a}
  libllvm3.6:i386{a} libltdl7:i386{a} libmpg123-0:i386{a} libogg0:i386{a} libopenal1:i386{a} liborc-0.4-0:i386{a} libosmesa6{a}
  libosmesa6:i386{a} libp11-kit0:i386{a} libpcap0.8:i386{a} libpciaccess0:i386{a} libpulse0:i386{a} libroken18-heimdal:i386{a}
  libsamplerate0:i386{a} libsane:i386{a} libsasl2-2:i386{a} libsasl2-modules:i386{a} libsasl2-modules-db:i386{a}
  libsndfile1:i386{a} libspeexdsp1:i386{a} libsqlite3-0:i386{ab} libssl1.0.0:i386{a} libtasn1-6:i386{a} libtiff5:i386{a}
  libtxc-dxtn-s2tc0:i386{a} libusb-1.0-0:i386{a} libv4l-0:i386{a} libv4lconvert0:i386{a} libvorbis0a:i386{a}
  libvorbisenc2:i386{a} libvpx1:i386{a} libwind0-heimdal:i386{a} libwrap0:i386{a} libx11-xcb1:i386{a} libxcb-dri2-0:i386{a}
  libxcb-dri3-0:i386{a} libxcb-glx0:i386{a} libxcb-present0:i386{a} libxcb-sync1:i386{a} libxcomposite1:i386{a}
  libxcursor1:i386{a} libxi6:i386{a} libxinerama1:i386{a} libxml2:i386{a} libxpm4:i386{a} libxrandr2:i386{a}
  libxshmfence1:i386{a} libxslt1.1:i386{a} libxt6:i386{a} libxxf86vm1:i386{a} ocl-icd-libopencl1:i386{a}
  p11-kit-modules:i386{a} wine-gecko2.34{a} wine-gecko2.34:i386{a} wine-mono4.5.4{a} wine1.8 wine1.8-amd64{a}
  wine1.8-i386:i386{a}
0 packages upgraded, 108 newly installed, 0 to remove and 3 not upgraded.
Need to get 184 MB of archives. After unpacking 615 MB will be used.
 libsqlite3-0 : Breaks: libsqlite3-0:i386 (!= 3.8.4.3-3) but 3.8.2-1ubuntu2.1 is to be installed.
 libsqlite3-0:i386 : Breaks: libsqlite3-0 (!= 3.8.2-1ubuntu2.1) but 3.8.4.3-3 is installed.
The following actions will resolve these dependencies:
      Keep the following packages at their current version:
1)      libgssapi3-heimdal:i386 [Not Installed]
2)      libheimntlm0-heimdal:i386 [Not Installed]
3)      libkrb5-26-heimdal:i386 [Not Installed]
4)      libldap-2.4-2:i386 [Not Installed]
5)      libsqlite3-0:i386 [Not Installed]
6)      wine1.8 [Not Installed]
7)      wine1.8-amd64 [Not Installed]
8)      wine1.8-i386:i386 [Not Installed]
      Leave the following dependencies unresolved:
9)      wine-gecko2.34 recommends wine1.5-amd64
10)     wine-gecko2.34:i386 recommends wine1.5-i386:i386
Accept this solution? [Y/n/q/?] n
open: 794; closed: 954; defer: 734; conflict: 1264        oInternal error: found 2 (choice -> promotion) mappings for a single choice.
open: 823; closed: 964; defer: 742; conflict: 1272
^C
Using apt-get I'm seeing:
> env LC_ALL=C sudo apt-get -V install wine1.8
Reading package lists... Done
Building dependency tree
 wine1.8 : Depends: wine1.8-i386 (= 1:1.8.0-0ubuntu1)
Exit 100
The alternative seems to be to uninstall just about everything else I need, which is evidently not an option.
Is there a workaround, preferably one that doesn't involve setting up an appropriate PPA myself?
For the record: the 3 not upgraded packages mentioned are held packages that are not broken and have nothing to do with wine.
RJVB
  • 211
Thanks Hi-Angel.
The issue here was indeed a package version conflict situation. It turns out that I backported that 3.8.4 sqlite3 package from (then) Debian Testing about 2y ago, and then completely forgot about it. Evidently. I didn't use a PPA, so got only the 64-bit packages.
I solved the issue by grabbing an even more recent 3.8 version (3.8.11) from Launchpad, and uploading that package to one of my PPAs (ppa:rjvbertin/misc in case anyone is interested). That was the most straightforward way to get all installed sqlite3 packages on the same version - and then wine1.8 installed fine.
RJVB
  • 211
