I run this cmd to backup my folders:
$ rsync -av --exclude {/mnt/dati/Film/, /mnt/dati/Scout/} --delete /mnt/dati/ /media/cirelli/HD1TB/backup/dati
sending incremental file list
And rsync answer is:
rsync: link_stat "/mnt/dati/Scout/}" failed: No such file or directory (2)
but "Scout" directory exist! Can't understand what I mistake. Even Film is copied, even if there isn't any error message! What's wrong in my execution of rsync?
Thank you very much folks
(oh, I have read man https://download.samba.org/pub/rsync/rsync.html and examples http://www.thegeekstuff.com/2011/01/rsync-exclude-files-and-folders/ but still find any way to solve..!)
I also tried (this is interrupted by CTRL+C):
cirelli@asus:~$ rsync -av --exclude /mnt/dati/Film/ --exclude /mnt/dati/.Trash-1000/ --delete /mnt/dati/ /media/cirelli/HD1TB/backup/dati
deleting Documenti/script/
rsync: readlink_stat("/media/cirelli/HD1TB/backup/dati/Documenti/RPi/.2015-05-05-raspbian-wheezy.zip.2sXers") failed: Input/output error (5)
deleting Documenti/RPi/KODI/
deleting Documenti/RPi/berryboot-20130908.zip
deleting Documenti/RPi/2015-05-05-raspbian-wheezy.zip
IO error encountered -- skipping file deletion
.Trash-1000/files/
.Trash-1000/files/2015-05-05-raspbian-wheezy.zip
.Trash-1000/files/berryboot-20130908.zip
.Trash-1000/files/settembre 12.img
^Crsync error: received SIGINT, SIGTERM, or SIGHUP (code 20) at rsync.c(632) [sender=3.1.1]
rsync: [sender] write error: Broken pipe (32)
Cirelli94
  • 626
  • 26
The first problem is in your brace expansion {}, which is done by the shell and rsync is just using the result.
You have made the brace expansion an no-op by introducing a space between the directory names, so to rsync the --exclude option has become:
so rsync will exclude the file (or directory) {/mnt/dati/Film/, (presumable there is no such) and the /mnt/dati/Scout/} has become a source file to copy for rsync and there no such file/directory, hence the error message.
To solve this brace expansion issue, you need to remove the space between the directory names:
{/mnt/dati/Film/,/mnt/dati/Scout/} ....
Or better just use the common part once:
/mnt/dati/{Film/,Scout/} ....
But this does not solve the problem with rsync because --exclude takes a pattern like:
--exclude='foo*bar'
or
--exclude 'foo*bar'
so in this case too, the directory /mnt/dati/Scout/ will still be taken as a source directory to copy from.
To solve this problem too you can use multiple --exclude:
rsync -av --exclude=/mnt/dati/Film/ --exclude=/mnt/dati/Scout/ ....
Or save the patterns in a file and use:
rsync -av --exclude-from=/file/with/patterns ....
heemayl
  • 93,925
