I have a recent installation of Ubuntu 14.04.4 that is freezing at the "Loading initial ramdisk" stage of booting. What is the best way to troubleshoot this?
The hardware is a Lenovo Thinkpad e410, with an Intel i3 processor, Intel graphics, and a hardware-encrypted Samsung SSD. Ubuntu is installed under UEFI, and the kernel version is 4.2.0-35.
Everything was fine until a few days ago, except that graphics hardware acceleration was (sometimes? always?) not working correctly (images cutting into other windows, flashing blue, etc.). I eventually traced this to this bug and applied the fix suggested at #9, running "sudo update-initramfs -u -k all" afterwards. After the fix, the i915 driver did appear to load correctly, but it still did not appear to be working correctly. I then did two things: (1) updated the system, and (2) installed Flash for Firefox. Everything still appeared to be fine, with the exception of the graphics.
This morning, when I started my computer, the cursor was gone in Unity. I could still access the terminal, and decided to try undoing the above bug fix, running update-initramfs again afterwards. Rebooting, it froze at the urple screen. Rebooting via grub2's advanced menu, normal boot mode freezes at "Loading initial ramdisk." Recovery mode loads the ramdisk, then generates a few screens worth of errors including:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
...[5 lines + call traces omitted]...
---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
...[more lines + call traces omitted]...
---[ end trace ... ]---
And that's it. Results are the same if I try booting into 4.2.0-27, in both normal (freezes at "Loading initial ramdisk") and recovery (lots of kernel panic output, then freeze) modes.
I can try modifying grub boot options, but I'm not sure how to do this in grub2 or which options to try. Or I can try booting the live disk, mounting the hard drive, and poking around from there, but I don't really know where to begin.
Any suggestions very much appreciated.
I made the mistake of assuming all the background was part of the problem, when the problem was just that grub2 couldn't find the system:
Kernel panic - not syncing: VFS: Unable to mount root fs...
I imagine the cause is that I forgot to run "sudo update-grub2" after running "sudo update-initramfs."
The solution turned out to be to boot to a Live CD, mount and chroot to the hard drive, and re-run update-initramfs and update-grub2, as detailed here.
Two complications I encountered were:
  1. "fdisk -l" doesn't work on GPT volumes; you have to use "gdisk -l" instead.
  2. I have /boot and / on different volumes, and / is encrypted.
So I needed to modify the mount sequence as follows:
sudo cryptsetup luksOpen /dev/sdaX sdaX_crypt
sudo mount /dev/mapper/sdaX_crypt /mnt
sudo mount /dev/sdaY /mnt/boot
sudo mount --bind /dev /mnt/dev
sudo mount --bind /dev/pts /mnt/dev/pts
sudo mount --bind /proc /mnt/proc
sudo mount --bind /sys /mnt/sys
sudo chroot /mnt
So I am back into my system, though I still don't have a cursor. But that is another problem.
I'm not sure on the etiquette, but since this ranks high in a web search I figured I'd leave my solve for the issue here as well.
In my case the problem came about after using a USB flash drive (for storage, this is not my boot device) in xubuntu, then restarting and booting into windows, flash drive still in. After shutting down windows, I physically removed the flash drive.
Once I booted back to xbuntu I got a black screen. After trying to load an older kernel, I got the above mentioned “Loading initial ramdisk” freeze.
I fixed it by inserting the thumb drive into the same slot again, booting into windows, shutting down, then booting into xubuntu. I then unmounted the volume, removed it and restart without a problem.
Note that I was not able to boot into xubuntu simply by inserting the flash drive again, I had to boot into windows first.
Hopefully this helps someone out there.
Tony
  • 36
