14
When I log in to Skype, the Skype icon doesn't show up on the app indicator (tray/menu bar right side) on Ubuntu 16.04 Xenial.
I've tried the installing the libappindicator1 as suggested here, and it worked for Slack, but not for Skype. I've also tried intalling sni-qt, but it was already installed: sni-qt is already the newest version (0.2.7+15.10.20150729-0ubuntu1)..
How can I fix this?
Zoltán
  • 826
Be sure to have sni-qt installed for i386 :
sudo apt-get install sni-qt:i386
Vita
  • 49
nniico
  • 306
15
For me on Ubuntu 16.10 installing libappindicator1 and restarting skype solved the problem
sudo apt-get install libappindicator1
Leszek
  • 3,209
Note that solutions mentioned here do not work with Ubuntu 17.04 due to a different reason mentioned here:
Also note that sni-qt:i386 package and all qt i386 dependencies are not required for "amd64" version of skypeforlinux. Instead you can use following workaround mentioned in the Unity bug:
$ env XDG_CURRENT_DESKTOP=Unity skypeforlinux
This will launch skypeforlinux with environment variable XDG_CURRENT_DESKTOP set to Unity, the default value of this variable in Ubuntu 17.04 is XDG_CURRENT_DESKTOP=Unity:Unity7 that confuses the electron (which Skype for Linux is build upon).
You can also use this line in the Startup Application entry, but then you should disable "Launch at Login" in Skype and create your own entry.
