Tried installing npm on ubuntu 14.04 however the following error has occurred
gwt@gwt-Aspire-E1-571:~$ sudo apt-get install npm
Reading package lists... Done
Building dependency tree
 npm : Depends: nodejs but it is not going to be installed
       Depends: node-abbrev (>= 1.0.4) but it is not going to be installed
       Depends: node-ansi but it is not going to be installed
       Depends: node-archy but it is not going to be installed
       Depends: node-block-stream but it is not going to be installed
       Depends: node-fstream (>= 0.1.22) but it is not going to be installed
       Depends: node-fstream-ignore but it is not going to be installed
       Depends: node-github-url-from-git but it is not going to be installed
       Depends: node-glob (>= 3.1.21) but it is not going to be installed
       Depends: node-graceful-fs (>= 2.0.0) but it is not going to be installed
       Depends: node-inherits but it is not going to be installed
       Depends: node-ini (>= 1.1.0) but it is not going to be installed
       Depends: node-lockfile but it is not going to be installed
       Depends: node-lru-cache (>= 2.3.0) but it is not going to be installed
       Depends: node-minimatch (>= 0.2.11) but it is not going to be installed
       Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed
       Depends: node-gyp (>= 0.10.9) but it is not going to be installed
       Depends: node-nopt (>= 2.1.1) but it is not going to be installed
       Depends: node-npmlog but it is not going to be installed
       Depends: node-once but it is not going to be installed
       Depends: node-osenv but it is not going to be installed
       Depends: node-read but it is not going to be installed
       Depends: node-read-package-json (>= 1.1.0) but it is not going to be installed
       Depends: node-request (>= 2.25.0) but it is not going to be installed
       Depends: node-retry but it is not going to be installed
       Depends: node-rimraf (>= 2.2.2) but it is not going to be installed
       Depends: node-semver (>= 2.1.0) but it is not going to be installed
       Depends: node-sha but it is not going to be installed
       Depends: node-slide but it is not going to be installed
       Depends: node-tar (>= 0.1.18) but it is not going to be installed
       Depends: node-which but it is not going to be installed
Kindly advice a solution to this problem as unable to proceed further.
muru
  • 207,228
This should solve your problem:
sudo apt-get update --fix-missing
Hope this works out!
megubyte
  • 1,164
Urjit
