I used to use this answer to set my terminal colors to black on white from the command line as follows.
gconftool-2 --set "/apps/gnome-terminal/profiles/Default/use_theme_colors" --type bool false
gconftool-2 --set "/apps/gnome-terminal/profiles/Default/foreground_color" --type string "#000000000000"
gconftool-2 --set "/apps/gnome-terminal/profiles/Default/background_color" --type string "#FFFFFFFFDDDD"
Unfortunately, while the values are set when I run these commands in Ubuntu 15.10, the gnome-terminal colors do not change at all.
What is the correct way to set terminal colors from the CLI in 15.10?
merlin2011
  • 599
  • 17
