:~$ sudo apt-get remove nginx* && sudo apt-get install nginx-full*
Reading package lists... Done
Building dependency tree
After this operation, 5,579 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://in.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 nginx-full-dbg amd64 1.10.0-0ubuntu0.16.04.1 [3,789 kB]
Fetched 3,789 kB in 33s (112 kB/s)
Selecting previously unselected package nginx-common.
(Reading database ... 189767 files and directories currently installed.)
Preparing to unpack .../nginx-common_1.10.0-0ubuntu0.16.04.1_all.deb ...
Unpacking nginx-common (1.10.0-0ubuntu0.16.04.1) ...
Selecting previously unselected package nginx-full.
Preparing to unpack .../nginx-full_1.10.0-0ubuntu0.16.04.1_amd64.deb ...
Unpacking nginx-full (1.10.0-0ubuntu0.16.04.1) ...
Selecting previously unselected package nginx-full-dbg.
Preparing to unpack .../nginx-full-dbg_1.10.0-0ubuntu0.16.04.1_amd64.deb ...
Unpacking nginx-full-dbg (1.10.0-0ubuntu0.16.04.1) ...
Processing triggers for ufw (0.35-0ubuntu1) ...
Rules updated for profile 'Apache Full'
Rules updated for profile 'Nginx HTTP'
Processing triggers for systemd (229-4ubuntu4) ...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for man-db (2.7.5-1) ...
Setting up nginx-common (1.10.0-0ubuntu0.16.04.1) ...
Setting up nginx-full (1.10.0-0ubuntu0.16.04.1) ...
Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
invoke-rc.d: initscript nginx, action "start" failed.
dpkg: error processing package nginx-full (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of nginx-full-dbg:
nginx-full-dbg depends on nginx-full (= 1.10.0-0ubuntu0.16.04.1); however:
Package nginx-full is not configured yet.
dpkg: error processing package nginx-full-dbg (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
nginx-full
nginx-full-dbg
Shutting down apache2 first before installing nginx should fix this problem:
sudo service apache2 stop
- 113
- 1,481
Andrew Chan provided the right answer for me. To extend his answer a bit, here's what you can do on the commandline;
stop apache2
sudo systemctl stop apache2.service
prevent apache2 to start at boot
sudo systemctl disable apache2.service
Reinstall nginx
- 281
In my case the error is the server has IPv6 disabled. Solution:
Edit /etc/nginx/sites-enabled/default and comment IPv6 out:
listen [::]:80 default_server;
Reinstall nginx:
apt purge nginx
apt autoremove
apt install nginx
- 33,815
- 111
I just had this issue, but the solution was slightly different.
Once I solved a simple site misconfiguration, I was able to update nginx.
Check your nginx error log:
sudo cat /var/log/nginx/error.log|less
Then try again:
sudo apt-get update;sudo apt-get upgrade
- 975
- 109
In my case nothing helped at all, except of this:
sudo fuser -k 80/tcp
service nginx start
- 121
Before the installation remove any manually added symlinks from /sites-enabled.
- 36,890
- 56
- 97
- 151
- 11
In my case it has been a misconfigurated file in /etc/nginx/sites-enabled/ I named them as .old files, but that does not matter. They will be readed and may prevend an successfull installation or start of that service. Be careful with files in that folder and read your error output carefully as discribed by @Taiger
- 11
When I checked /var/log/nginx/error.log I saw that the installer was unable to open /var/cache/nginx/microcache
A directory listing showed there was no /var/cache/nginx directory, so I created it and the install succeeded.
I see you want to reinstall Nginx, but we can have the same error when we have Nginx run in Docker container.
In this case, just look at started containers:
user@host:~$ docker ps
CONTAINER ID IMAGE COMMAND CREATED
STATUS PORTS NAMES
f4ee2264d5fb docker_nginx "nginx -g 'daemon of…" 5 months ago Up 2 days 0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp nginx
Just stop it with CONTAINER ID
docker stop f4ee2264d5fb
Then you are able to install Nginx
