I created a boot able flash drive using this procedure:
http://www.ubuntu.com/download/desktop/create-a-usb-stick-on-windows
I then used this to upgrade Ubuntu to the current version.
After the upgrade, I can not get the windows boot loader to come up no matter what hard drive I try to boot from and the Ubuntu boot loader only shows Ubuntu where as the previous version would also give Windows as an option. What do I need to do to fix this?
Hizqeel
  • 1,915
  • 28
  • 24
  • 24
  1. restart
  2. press the boot menu key(for me it was f10)
  3. select windows hdd
  4. until now I am using these steps
  5. backup your data after going to the windows os
  6. search for more answers after backing it up/else do steps 1 to 4 whenever you want windows
  7. Enjoy
Boot from a Ubuntu flashdrive again and select try ubuntu option. Then install Boot Repair on the live session and run it with recommended options. I believe it will fix the problem otherwise post the pastebin link that boot-repair provides here.
Try opening a terminal and running sudo update-grub. This command should automatically search for and add all OSes found to the GRUB boot menu.
I'd recommend trying this before trying boot-repair.
