I'm using Ubuntu 15.10 and I want to change deja-dup default settings (location and schedule), but I don't see the option on system settings:
System settings
I removed and re-installed deja-dup and it's working, because I can run it from the terminal, but deja-dup --backup starts immediatily the backup and I can't access the settings.
As far as I can see in man deja-dup there is also no option to do this on terminal.
I remember I saw the backup icon in system settings in 14.04, but now it's gone (neither appears when I search "Backup" on the Dash), do you know what's wrong?
Deja-dup preferences should be available from the command line by running:
deja-dup-preferences
Also this question goes into how to add an item to the system settings. You can use
 locate "deja-dup-preferences.desktop"
to see if you have a .desktop file lying around to modify for this.
Or you could just put the following into a new file at "/usr/share/applications/deja-dup-preferences.desktop"
[Desktop Entry]
Version=1.0
X-Ubuntu-Gettext-Domain=deja-dup
Name=Backups
Comment=Change your backup settings
Icon=deja-dup
TryExec=deja-dup-preferences
StartupNotify=true
Type=Application
Categories=Settings;Utility;Archiving;GNOME;GTK;X-GNOME-SystemSettings;
NotShowIn=Unity;
# Translators: Add whatever keywords you want in your language, separated by semicolons
# These keywords are used when searching for applications in dashes, etc.
Keywords=déjà;deja;dup;
X-AppInstall-Ignore=true
Actions=BackUpNow;
[Desktop Action BackUpNow]
Name=Back Up
Exec=deja-dup --backup
That should give you back the system settings icon after a new login I think.
vlz
  • 180
