12
How to set Super key (release) as a shortcut for xfce4-popup-whiskermenu. Its currently set to Ctrl/primary+esc.
I am using Xubuntu 16.04
cipricus
  • 4,066
  • 47
  • 106
Severus Tux
  • 10,126
Open whiskermenu, type "keyboard" and hit enter. Then choose "Shortcut for application" and find the entry for xfce4-popup-whiskermenu. Dubble-click the assigned shortcut. Now press Super-key. Done.
Ben
  • 119
This thread answers this question in a way that still allows using e.g. Super+E to open the file manager.
Basically for Xubuntu:
  • sudo apt install -y xcape
  • click the menu button, find "Session and Startup" and add a new entry in the "Application Autostart" tab. Use any name you like and put this in the Command field:
    xcape -e 'Super_L=Shift_L|Control_L|Alt_L|Super_L|D'
    It's remapping the Super key to another, more complicated shortcut that 's unlikely to be used.
  • assign the same complicated key combination to xfce4-popup-whiskermenu in the standard shortcut manager (click menu, type "keyboard", press Enter, the rest should be obvious)
Rafał G.
  • 171
