android@android:~$ gufw
No protocol specified
Unable to init server: Could not connect: Connection refused
(gufw.py:21126): Gdk-CRITICAL **: gdk_keymap_get_for_display: assertion 'GDK_IS_DISPLAY (display)' failed
(gufw.py:21126): Gdk-CRITICAL **: gdk_keymap_get_modifier_mask: assertion 'GDK_IS_KEYMAP (keymap)' failed
(gufw.py:21126): Gtk-CRITICAL **: _gtk_replace_virtual_modifiers: assertion 'GDK_IS_KEYMAP (keymap)' failed
/usr/bin/gufw-pkexec: line 13: 21126 Segmentation fault (core dumped) python3 ${LOCATIONS[${i}]} $1
- 1,493
I'm a Gufw developer.
You can not run any root UI (Gparted, Synaptic, Gufw...) because of Wayland.
Related bug: https://bugs.launchpad.net/ubuntu/+source/gui-ufw/+bug/1713238
All info here: https://bugs.launchpad.net/ubuntu/+source/backintime/+bug/1713313/comments/44
As you can read in that link, I'm afraid that it will be not fixed, because it was closed as won't fix :/
https://bugzilla.redhat.com/show_bug.cgi?id=1274451
A hug and I'm so sorry.
- 2,318
A dirty workaround, but this is one way to make gufw work on Ubuntu 17.10 with Wayland:
Create the file
~/bin/gufwand give it this contents:#!/bin/sh xhost SI:localuser:root /usr/bin/gufw xhost -SI:localuser:rootMake the file executable:
chmod +x ~/bin/gufw
Edit:
A more step by step explanation would be:
- Press Ctrl+Alt+T to open a terminal window.
Run the command:
mkdir -p bin(i.e. type it and press Enter)
Open the gedit text editor with this command:
gedit bin/gufwCopy the contents as above and paste it into the gedit window.
Save and quit gedit.
Run the command:
chmod +x bin/gufwQuit the terminal window by running the command:
exit
- 34,191
Re-installation not really required;
After a quick search, I found that Gufw is missing a python dependency. It appears that the python-gi package needs to be added as a dependency.
Steps to fix:
- sudo apt install python-gi
- gufw
- Type in password
- 33,815
- 31
I had the same issue. Accidentally found the solution for gparted over SSH here.
sudo -E gufw
This should work - assuming /etc/ssh/sshd_config is properly configured.
- 20,055
- 57
- 82
- 84
- 1
xhost si:localuser:root
pip3 install ufw
sudo apt-get install python-gobject
sudo apt-get install --reinstall gufw
sudo gufw
worked for me on Ubuntu 18.04! I had the same issue! I hope I'm not forgetting any cmd as I tried a lot of things...
