I have an issue with Ubuntu Software Center. It's not allowing me to install software that I had previously downloaded. For example, if I download Google Earth (x64), Ubuntu Software Center opens, and when I click install, it hangs and does not install the application.
That happens to me with all the softwares I have downloaded (Vivaldi, Chrome, Opera, Polarr; N1, ...). Although I have these softwares installed, because I did it under Ubuntu 15.10(x64) and then upgrade to version 16.04LTS (x64). Is there any way to fix it or using another installer?, or, How I could use Synaptic to install pre-downloaded software?. Thanks.
kelvinelove
  • 1,619
Javier
You can do this with gdebi the 16.04 Software Center is actually bugged, so till a fix hits live use gdebi. To install gdebi do in terminal (ctrl+alt+t):
sudo apt-get install gdebi
After that start it with:
gksudo gdebi-gtk
This will after prpomting you for your password open the Gdebi-GUI version.
Now just open your .deb file by
File --> open
Then hit install package. This way you mostly wont run into dependency problems.
Another solution is doing it via terminal with dpkg(ctrl+alt+t):
sudo dpkg -i <packagename>.deb
If you run into messages saying something about unmet dependencies do
sudo apt-get -f install
this will aswell do it, but the gdebisolutioin is more hassle free.
Videonauth
  • 33,815
