15
I have installed Ubuntu 16.04 and I haven't any problem in live. But after the login, mouse doesn't move and click. the only solution I found was:
sudo rmmod usbhid
sudo modprobe usbhid
However, I have to run the commands every time I want to use the mouse, some other solution?
I also tried adding usbhid in /etc/modules
OUTPUT dmesg:
[   88.343508] usb 2-1.2: Product:  USB OPTICAL MOUSE
[   88.346159] input:  USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:15D9:0A4C.0002/input/input15
[   88.402897] hid-generic 0003:15D9:0A4C.0002: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.0-1.2/input0
[   88.917503] usb 2-1.2: input irq status -75 received
Not answer, just information.
Fedora user has same problem. https://bugzilla.redhat.com/show_bug.cgi?id=1277837
In above url, developer suggest to try to stop fwupd by setting EnableOptionROM=false in /etc/fwupd.conf.
Or prevent to start gnome-software by removing "/etc/xdg/autostart/gnome-software-service.desktop".
shibata
  • 66
I have the same problem. When I disconnect and reconnect the mouse after modprobe, the problem returns, with the same symptoms.
Some logs:
dmesg after disconnecting:
[252703.806012] usb 2-1.2: USB disconnect, device number 9
After reconnecting:
[252795.656346] usb 2-1.2: new low-speed USB device number 10 using ehci-pci
[252795.753417] usb 2-1.2: New USB device found, idVendor=15d9, idProduct=0a4c
[252795.753424] usb 2-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[252795.753428] usb 2-1.2: Product:  USB OPTICAL MOUSE
[252795.756554] input:  USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:15D9:0A4C.0012/input/input33
[252795.757510] hid-generic 0003:15D9:0A4C.0012: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.0-1.2/input0
When moving the mouse/clicking after that:
[252897.603985] usb 2-1.2: input irq status -75 received
[252897.683981] usb 2-1.2: input irq status -75 received
that could be dozens of messages just the same.
After rmmod:
[253044.509863] usbcore: deregistering interface driver usbhid
After modprobe:
[253070.755169] input: HID 1267:0103 as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/0003:1267:0103.0013/input/input34
[253070.811506] hid-generic 0003:1267:0103.0013: input,hidraw0: USB HID v1.10 Keyboard [HID 1267:0103] on usb-0000:00:1d.0-1.1/input0
[253070.816279] input: HID 1267:0103 as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:1267:0103.0014/input/input35
[253070.871361] hid-generic 0003:1267:0103.0014: input,hidraw1: USB HID v1.10 Device [HID 1267:0103] on usb-0000:00:1d.0-1.1/input1
[253070.874103] input:  USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:15D9:0A4C.0015/input/input36
[253070.927229] hid-generic 0003:15D9:0A4C.0015: input,hidraw2: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.0-1.2/input0
[253070.927285] usbcore: registered new interface driver usbhid
[253070.927288] usbhid: USB HID core driver
...and now it works again.
A K
  • 121
