I recently dual booted a laptop with the recently released 16.04. I first attempted to install VLC media player from the Software Center, and like many others I'm unable to do that (or any third party applications).
I then attempted to install VLC from the terminal.
sudo apt-get install vlc
I receive an error stating I have unmet dependencies:
"Building dependency tree
 vlc : Depends: vlc-nox (= 1:2.0.6-dmo3) but it is not going to be installed
       Depends: libavcodec54 (>= 8:1.0.0) but it is not going to be installed
       Recommends: vlc-plugin-notify (= 1:2.0.6-dmo3) but it is not going to be installed
       Recommends: vlc-plugin-pulse (= 1:2.0.6-dmo3) but it is not going to be installed
E: Unable to correct problems, you have held broken packages."
I've tried every fix listed for similar problems I could find on this site but none seem to correct my issue.
Videonauth
  • 33,815
