when I try sudo apt install rhythmbox I get this:
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
 rhythmbox : Depends: librhythmbox-core9 (= 3.3-1ubuntu7) but 3.3.0.0-1~wilyubuntu2 is to be installed
             Depends: rhythmbox-data (= 3.3-1ubuntu7) but 3.3.0.0-1~wilyubuntu2 is to be installed
             Depends: gir1.2-rb-3.0 (= 3.3-1ubuntu7) but 3.3.0.0-1~wilyubuntu2 is to be installed
             Recommends: rhythmbox-plugins but it is not going to be installed
             Recommends: rhythmbox-plugin-zeitgeist but it is not going to be installed
I tried using ppa:fossfreedom/rhythmbox as a source as well but that responds with this:
E: The repository 'http://ppa.launchpad.net/fossfreedom/rhythmbox/ubuntu xenial Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
I tried making sure I didn't have any weird sources enabled and even deleted anything related to rhythmbox from /etc/apt/sources.list.d Regular install from Software doesn't work either.
Any ideas?
Thanks
Seth
  • 59,332
kartak
  • 23
The ppa versioned it's rhythmbox packages incorrectly in wily so they are are higher than the rhythmbox packages in xenial.
xenial - 3.3-1ubuntu7
ppa - 3.3.0.0-1~wilyubuntu2
3.3.0.0 is higher than 3.3, to fix just remove all Rb source packages, update sources & install Rb from Ubuntu repos
doug
  • 17,212
I had this same problem. I believe Doug is right about the Wily ppa. I purged rhythmbox and all rhythmbox data. I also purged the fossfreedom ppa. Then I found the Rhythmbox deb file for Rhythmbox 3.3-1 (the Xenial version rather than the Wily version) on pkgs.org and was able to install Rhythmbox that way. I can't find a ppa at the moment that has the Xenial version. Hopefully fossfreedom will update his ppa soon.
amadis
  • 61
