Using /etc/sudoers I gave a non-root user (anyuser below) permission to sudo-execute a root-owned script (test-script below) with the NOPASSWD: tag set.
The script's permission octal value is 0550. Its execution is possible only with one predefined argument (cache_bak below) and when the script file was not tampered with. The latter is possible based on a SHA256 digest-conditioned execution (relevant info in sudoers man page).
Things work well , ... until I test-modify the script to get a different SHA digest and see how sudoers handles it.
What I did was:
$ cat /home/anyuser/Scripts/test-script
#!/bin/bash
/bin/mkdir -p /var/"$1"
/bin/cp -R /var/cache/* /var/"$1" # copies content of /var/cache/
# to /var/$1, defined by script's lone arg
exit $?
# End of test-script
$ sudo chmod 0550 /home/anyuser/Scripts/test-script
$ sudo chown root:admin /home/anyuser/Scripts/test-script
$ ls -lsAF test-* # check
4 -r-xr-x--- 1 root admin 75 Apr 25 18:23 test-script*
$ cat /etc/group | grep sudo # check
sudo:x:27:anyuser
$ sudo cat /etc/sudoers # check
Defaults env_reset
Defaults mail_badpass
Defaults secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
Defaults insults
root ALL = (ALL:ALL) ALL
%sudo ALL = (root:ALL) ALL
%admin ALL = (ALL:ALL) ALL
%wheel Somehost = (ALL:ALL) ALL
#includedir /etc/sudoers.d
I then populated /etc/sudoers.d with 10_user, whose content is:
$ cat /etc/sudoers.d/10_user
Cmnd_Alias CPVARCACHE = sha256:48805bae82834f323xxxxxxxxxxxxx10145c7bbf80bae183b7de3ea52ef90637 /home/anyuser/Scripts/test-script cache_bak
# GROUP SPECS
%admin Somehost = NOPASSWD: /usr/bin/rsync
# USER SPECS
anyuser Somehost = (root) NOPASSWD: CPVARCACHE
Everything works well, i.e. no passwd is requested and the copy-job gets done, until I simulate having tampered with test-script. I did so by adding a line to it, e.g. if [ "$1" ] ;then :; fi and running: sudo /home/anyuser/Scripts/test-script cache_bak again.
The sudo shell does not abort as I expected. Instead it checks that the SHA digest has become different and requests a password for anyuser to carry out the job. However, in that case, I want the line cmd to abort unattended (quietly).
Attempting to redirect stdout and stderr to /dev/null:
# after modifying the script so its SHA digest is different from
#+ that in '/etc/sudoers.d/10_user'
$ sudo /home/anyuser/Scripts/test-script cache_bak > /dev/null 2>&1
[sudo] password for anyuser: _^C
The above only redirects output of the subshell process, not that of the sudo process.
If the script is tampered with I need the sudo process to abort, presumably even before it launches the script... I saw interesting stuff (e.g. this), but nothing really relevant...
