Yesterday I failed to successfully install owncloud on my ubuntu desktop. The current issue that I am facing is when I go to my owncloud page I get the error:
PHP is configured to populate raw post data. Since PHP 5.6 this will lead to PHP throwing notices for perfectly valid code.
To fix this issue set always_populate_raw_post_data to -1 in your php.ini
This was not a setting in anp php.ini file, I added it anyway but to no avail. When I tried to update owncloud I got the error that I was missing a public key so I got I new key using apt-key. I now get the warning:
W: http://download.opensuse.org/repositories/isv:/ownCloud:/community/xUbuntu_14.04/Release.gpg: Signature by key F9EA4996747310AE79474F44977C43A8BA684223 uses weak digest algorithm (SHA1)
I understand that I may be too mired in my mistakes and lack of knowledge to be helped but I ask for advice on what do do, and if it is a lost cause how to remove everything. Thank you
There is problem with owncloud repos not supporting Ubuntu 16.04 yet. As a workaround you can manually download *.deb files for 15.10. But that's not very nice solution.
viky
  • 31
