After upgrading from 15.10 to 16.04, I am receiving the following error on apt-get update:
Reading package lists... Done
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/restricted/source/Sources  Empty files can't be valid archives
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/universe/source/Sources  Empty files can't be valid archives
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/multiverse/source/Sources  Empty files can't be valid archives
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/restricted/binary-amd64/Packages  Empty files can't be valid archives
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/restricted/binary-i386/Packages  Empty files can't be valid archives
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/restricted/i18n/Translation-en  Empty files can't be valid archives
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/universe/binary-amd64/Packages  Empty files can't be valid archives
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/universe/binary-i386/Packages  Empty files can't be valid archives
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/universe/i18n/Translation-en  Empty files can't be valid archives
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/multiverse/binary-amd64/Packages  Empty files can't be valid archives
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/multiverse/binary-i386/Packages  Empty files can't be valid archives
E: Some index files failed to download. They have been ignored, or old ones used instead.
Does anyone know how to solve this error?
orschiro
  • 13,687
5 Answers5
14
Go to "Ubuntu Software Center->Edit->Software Source"
select from "Download From" and choose "Other..." and click "Select Best Server". It will take some time... And it comes up with best server for you. Then chose that server and type command below again,
sudo apt-get update
I was getting this for the past few months after upgrading, but just running:
apt-get clean
fixed it. No need for changing the source servers as others have suggested.
Eborbob
  • 323
apt-get clean
worked for me in conjunction with:
apt-key update
and following the steps found in this answer:
Cannot solve GPG error
Solved using this:
sudo cd /etc/apt
sudo mv sources.list sources.list.ok
sudo echo <<EOF
deb mirror://mirrors.ubuntu.com/mirrors.txt xenial main restricted universe multiverse
deb mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates main restricted universe multiverse
deb mirror://mirrors.ubuntu.com/mirrors.txt xenial-backports main restricted universe multiverse
deb mirror://mirrors.ubuntu.com/mirrors.txt xenial-security main restricted universe multiverse
EOF > sources.list
sudo apt-get clean
sudo apt-get update
After update and upgrade, you can revert your sources.list to original !!
Videonauth
  • 33,815
I had this situation with a different archive. Finding and removing a 0 byte file from /var/lib/apt/lists fixed the problem for me.
gerardw
  • 521
