Using these instructions, I could get gedit 3.10.4 to run on ubuntu 16.04.
Now, I need to install the version of gedit-plugins that corresponds to gedit 3.10.4. The sources are here but I have not been able to get them to work.
More precisely, I did:
dpkg: error processing package gedit-plugins (--install):
 dependency problems - leaving unconfigured
Processing triggers for libglib2.0-0:amd64 (2.48.0-1ubuntu4) ...
 gedit-plugins
cd Downloads/
cd gedit-plugins-3.10.1/
./autogen.sh
But I get:
Configuration:
Source code location:   .
Compiler:               gcc
Prefix:         /usr/local
Python Plugins Support: yes
Plugins:                bookmarks bracketcompletion charmap codecomment colorpicker colorschemer commander dashboard drawspaces joinlines multiedit smartspaces textsize wordcompletion
Disabled plugins:       synctex (dbus-python not found), terminal (vte not found), git (libgit2-glib not found)
Note: you have to install these plugins into the same prefix as your gedit installation (probably /usr if you're using your distro packages, /usr/local if you have compiled it on your own).
So here is my question: how can I have gedit-plugins up and running? In particular, I need the terminal plugin to work.
P.S. I have already installed libvte-dev
Edit (wintermute's answer below)
yes, I have tried. Here is what I got:
Preparing to unpack gedit-plugins_3.10.1-1ubuntu2_amd64.deb ...
Unpacking gedit-plugins (3.10.1-1ubuntu2) over (3.10.1-1ubuntu3) ...
dpkg: dependency problems prevent configuration of gedit-plugins:
 gedit-plugins depends on python3.4; however:
  Package python3.4 is not installed.
 gedit-plugins depends on python3 (<< 3.5); however:
  Version of python3 on system is 3.5.1-3.
 gedit-plugins depends on gir1.2-gucharmap-2.90; however:
  Package gir1.2-gucharmap-2.90 is not installed.
 gedit-plugins depends on gir1.2-vte-2.90; however:
  Package gir1.2-vte-2.90 is not installed.
 gedit-plugins depends on gir1.2-zeitgeist-2.0; however:
  Package gir1.2-zeitgeist-2.0 is not installed.
user2413
  • 14,957
I had to find out that the build process isn't so easy to solve. However I found another approach for you to get the old version of gedit and gedit-r-plugin up and running.
First removing the traces of your gedit compiling and installing tries (change the paths respectively to fit your situation).
cd ~/your build dir of gedit-plugins/
sudo make uninstall
cd ~/your build dir of gedit/
sudo make uninstall
The next command uninstalls the eventually existing 3.18.3 version of gedit, gedit-dev, gedit-plugins and gedit-common.
sudo apt-get remove gedit gedit-dev gedit-plugins gedit-common
Best to do the following steps in a clean seperate directory.
Now downloading the proper dependencies package for gedit-common 3.10.4 and installing it.
wget http://mirrors.kernel.org/ubuntu/pool/main/g/gedit/gedit-common_3.10.4-0ubuntu13_all.deb
sudo dpkg -i gedit-common_3.10.4-0ubuntu13_all.deb
Then downloading the proper gedit 3.10.4 package and installing it
wget http://mirrors.kernel.org/ubuntu/pool/main/g/gedit/gedit_3.10.4-0ubuntu13_amd64.deb
sudo dpkg -i gedit_3.10.4-0ubuntu13_amd64.deb
And downloading the proper gedit-dev 3.10.4 package and installing it.
wget http://mirrors.kernel.org/ubuntu/pool/main/g/gedit/gedit-dev_3.10.4-0ubuntu13_amd64.deb
sudo dpkg -i gedit-dev_3.10.4-0ubuntu13_amd64.deb
Finaly downloading the proper gedit-plugins 3.10.1 package
wget http://mirrors.kernel.org/ubuntu/pool/universe/g/gedit-plugins/gedit-plugins_3.10.1-1ubuntu3_amd64.deb
We need to unpack this downloaded .deb file because we need to do two changes (sudo keps the packages owner intact).
sudo dpkg-deb -R gedit-plugins_3.10.1-1ubuntu3_amd64.deb tmp
First we are editing tmp/DEBIAN/control and change python3 (<< 3.5), python3 (>= 3.4~), python3.4 to python3 (>= 3.5~), python3.5.
sudo nano tmp/DEBIAN/control
Then we edit tmp/DEBIAN/postinstand change py3compile -p gedit-plugins /usr/lib/x86_64-linux-gnu/gedit/plugins -V 3.4 to py3compile -p gedit-plugins /usr/lib/x86_64-linux-gnu/gedit/plugins -V 3.5.
sudo nano tmp/DEBIAN/postinst
Now we can pack a new .deb file.
sudo dpkg-deb -b tmp gedit-plugins_3.10.1-1ubuntu4_amd64.deb
And changing ownership of the new .deb file (replace username with your username)
sudo chown username:username gedit-plugins_3.10.1-1ubuntu4_amd64.deb
Now finally installing it.
sudo dpkg -i gedit-plugins_3.10.1-1ubuntu4_amd64.deb
And now we download the proper gedit-r-plugin 0.8.0.2 package and install it.
wget http://mirrors.kernel.org/ubuntu/pool/universe/g/gedit-r-plugin/gedit-r-plugin_0.8.0.2-Gtk3-Python3-1ubuntu1_all.deb
sudo dpkg -i gedit-r-plugin_0.8.0.2-Gtk3-Python3-1ubuntu1_all.deb
Only thing now left is protecting this all from upgrading.
sudo apt-mark hold gedit-common gedit gedit-dev gedit-plugins gedit-r-plugin
Videonauth
  • 33,815
Have you tried downloading the right version of the package compiled for an older release and installing it manually?
http://www.ubuntuupdates.org/package/core/trusty/universe/base/gedit-plugins for 3.10.1-1ubuntu2 from 14.04
http://www.ubuntuupdates.org/package/core/vivid/universe/base/gedit-plugins for 3.10.1-1ubuntu3 from 14.10
You can either use the graphic installer or install them from terminal with
$ dpkg -i ~/Downloads/package.deb
