14
This is a fresh install of Kubuntu 16.04 with all the latest updates applied.
I installed all of texlive: apt install texlive\* and then tried to install biber: apt install biber which wants to remove texlive-bibtex-extra. Trying to install both together: apt install biber texlive-bibtex-extra gives the following error:
Reading package lists... Done
Building dependency tree
texlive-bibtex-extra is already the newest version (2015.20160320-1).
 texlive-bibtex-extra : Breaks: biber (< 2.4) but 2.3-1 is to be installed
Does anyone have any insight into why the biber package is out of date wrt the texlive-bibtex-extra dependency?
I know I can grab the texlive distribution directly, but I would like to use the package manager if possible.
fraktur3d
  • 143
Based on this bug report, it looks like what you've found (and what I've also just encountered) is a bug that didn't get fixed in time for 16.04 .
Someone on that page suggested a workaround which involves downloading biber from source. You can consider that until it is finally fixed?
(Just tried it myself and confirmed that it works.)
(Edit: Note that it seems (the older) biber version 2.4 should be used. A newer version doesn't seem compatible with the biblatex that comes with Ubuntu 16.04)
Ray
  • 2,200
