Just did a clean install of 16.04 and my Logitech MX Master won't work. I even tried to use blueman to no avail.
Anyone get it working? I used blueman to get it working on 15.
Thanks in advance!
Contents of /var/lib/bluetooth///info
[General]
Name=MX Master
Appearance=0x03c2
AddressType=static
SupportedTechnologies=LE;
Trusted=false
Blocked=false
Services=00001800-0000-1000-8000-00805f9b34fb;00001801-0000-1000-8000-00805f9b34fb;0000180a-0000-1000-8000-00805f9b34fb;0000180f-0000-1000-8000-00805f9b34fb;00001812-0000-1000-8000-00805f9b34fb;00010000-0000-1000-8000-011f2000046d;
[DeviceID]
Source=2
Vendor=1133
Product=45074
Version=20
[ConnectionParameters]
MinInterval=6
MaxInterval=9
Latency=44
Timeout=216
I got it working by using the hciconfig answer here: https://askubuntu.com/a/660918/534356
Ironically I tried this before and it didn't work... but after re-installing Ubuntu 16 this did solve my problem!
Thanks @Tobi
Try adding the equivalent linkkey paragraph (use the Key your mouse has) to the info file and change the "Trusted" to true.
[LinkKey]
Key=532EE33E7E50E79AB350554D63226EA1
Type=4
PINLength=0
The trick is to find the key. It may be dug out of the Microsoft registry if you can pair the mouse on a Windows macnine, or on another linux machine. Older Ubuntu (bluez4) will have the keys in a file like /var/lib/bluetooth//linkkeys.
First try changing the "Trusted" and adding a linkkey with a bogus key like DEADBEEFDEADBEEFDEADBEEFDEADBEEF or any random hex value. Then remove the device from the pairing list and re-pair it. Hopefully the new key will be inserted and used to let the mouse work. Blueman has a trust button, try that if you didn't already.
ubfan1
  • 19,049
