I have a new System76 Lemur Laptop. It worked fine for a week. I installed Kubuntu, it worked fine. Then I upgraded to Kubuntu 16.04 LTS and the system doesn't boot fully anymore. The Kubuntu logo flashes but then never displays the login UI, I just see black. I can get a TTY by pressing CTRL+ALT+F1 key. I can run startx -- :1 from the TTY to get a bare bones graphical interface.
How can I get a usable graphical interface?
Eofla
  • 189
rrenaud
  • 213
sudo dpkg-reconfigure sddm
and selecting sddm worked for me.
Run
sudo apt-get install --reinstall kubuntu-desktop plasma-desktop plasma-desktop-data sddm xorg xserver-xorg-core xserver-xorg-video-intel && sudo dpkg-reconfigure sddm
The 1st part will reinstall kubuntu's KDE plasma, the X11 display server, the sddm display manager, and the intel video driver; the next will allow you to set it as the default display manager. If some of those packages aren't installed, it will attempt to install them.
Logs are located at /var/log. Look for the log for Xorg and sddm.
Note - This message only aims at proprietary nvidia drivers users. I'm not sure if your laptops has one, but it may help for other people that were in the same situation. :
I just encountered a similar issue after updating my Kubuntu 16.04 setup (it already worked fine with it). Messing around KDE packages didn't help. However I noticed that Plasma was actually working but I didn't get any real visual feedback (right click worked as if plasma was properly started). I could start in a konsole using alt+f2 and blindly launching it. Manually restarting KWin (kwin_x11 --replace) showed me that compositing got disabled because of the lack of GLX extension in the X server. It was confirmed by glxgears not willing to start.
So I dropped in a TTY, logged in, sudo service lightdm stop (note : the default DM under Kubuntu is sddm so it most likely would be sudo service sddm stop), reinstalled the nvidia drivers, rebooted and it was back working.
I wonder if it was just about the X.org config (so try messing around nvidia-xconfig first) that got replaced or if the upgrade nuked up some GLX libraries.
Hopefully this will help you and some others going by!
asu
  • 141
-1
Same problem. I held the shift key down during boot and got to a menu where I chose "advanced options," then selected "upstart." At least I can do my office work now. Unknown how to make systemd, the new type of booting up, function.
Craig
