Works fine with opensource drivers, but with catalyst flickers everytime you press on activities or the lower right bar.
I have 01:00.0 VGA compatible controller: ATI Technologies Inc Mobility Radeon HD 3600 Series
Running fresh ubuntu 11.10 and catalyst 11.10 from ati.com website.
Any suggestions?
EDIT: I want to use the proprietary drivers I know that opensource ones work fine.
This steps worked for me and what you probabably should do is upgrade you ATI drivers. They have solved a lot of those issues you're facing on.
http://www.upubuntu.com/2011/12/how-to-install-amd-catalyst-1112-linux.html
For smooth installation, it is recommended to uninstall currently availabe Catalyst driver. To do this, use these commands from the terminal:
sudo apt-get remove fglrx*
To install the AMD Catalyst 11.12 Linux driver now on Ubuntu 11.10 (32-bit & 64-bit) or any older version, run this sequence of commands:
cd ~/;
mkdir catalyst11.12;
cd catalyst11.12/
wget -O ati-driver-installer-11-12.run http://www2.ati.com/drivers/linux/ati-driver-installer-11-12-x86.x86_64.run
If you have a 64 bit system, then install this before anything
sudo apt-get install ia32-libs
After that you can start installing the new ati driver:
chmod +x ati-driver-installer-11-12.run
sh ./ati-driver-installer-11-12.run
Make now an update for the X.org file with this command:
sudo aticonfig --initial -f
sudo reboot
Hope this helps.
Mateo
  • 8,152
Jorge Pinho
  • 1,228
Uninstall proprietary drivers.
I did it last week and latest version of open source drivers works perfectly.
sudo apt-get remove --purge xserver-xorg-video-ati xserver-xorg-video-radeon
sudo apt-get install xserver-xorg-video-ati
sudo apt-get install --reinstall libgl1-mesa-glx:i386 libgl1-mesa-glx:amd64 libgl1-mesa-dri:i386 libgl1-mesa-dri:amd64 xserver-xorg-core
sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.backup
sudo rm -rf /etc/ati
Jorge Castro
  • 73,717
Blackhole
  • 320
try to remove Screenlets if you have ones, it helped for me (Ubuntu 11.10, AMD Proprietary Drivers 11.10).
-3
To solve this (with propietary drivers) install compiz manager, then go to OpenGL and make sure all the options are unchecked. Restart and you are good to go (:
victorhqc
  • 339
