15
With the Official Ubuntu 16.04 LTS (Xenial Xerus) Vagrant box image (on VirtualBox) I have problems with basic network settings:
My Vagrantfile:
Vagrant.configure(2) do |config|
  config.vm.box = 'ubuntu/xenial64'
  config.vm.define "xenial" do |server|
    server.vm.network "private_network", ip: "192.168.10.10"
  end
end
vagrant up result:
==> xenial: Configuring and enabling network interfaces...
The following SSH command responded with a non-zero exit status.
Vagrant assumes that this means the command failed!
/sbin/ifdown eth1 2> /dev/null
Stdout from the command:
Stderr from the command:
sudo: unable to resolve host ubuntu-xenial
mesg: ttyname failed: Inappropriate ioctl for device
Leaving the configuration to DHCP also does not work:
server.vm.network "private_network", type: "dhcp"
At the same time, the above configurations work for ubuntu/trusty64 and ubuntu/wily64 and unofficial gbarbieru/xenial.
Trying the command /sbin/ifdown eth1 2> /dev/null gives no results as the interface has different naming scheme (the main one is enp0s3).
Am I missing something obvious here or is the box just broken?
techraf
  • 3,316
5 Answers5
15
The problem seems to be solved in the next release of vagrant: https://github.com/mitchellh/vagrant/issues/7155
I tried another box from Jeff Geerling https://twitter.com/geerlingguy/status/723571293174427648?lang=fr and it worked perfectly for me. Jeff has done a lot of great work on Vagrant/Ansible so I guess it's the best solution before the release of the next version of Vagrant
Despite ubuntu/xenial64 is the Official Ubuntu box, it has some issues regarding network configuration and is not an Vagrant issue as is explained in @Maxime 's answer.
So, as in the issue is mentioned, is preferred to use a bento box (mantained by the comunity and with Opscode Chef as leader of the project), which for this case would be bento/ubuntu-16.04.
Alter Lagos
  • 1,209
I faced a similar issue as discussed in the original question.
I am using Vagrant 1.8.1. and using the ubuntu/trusty64 box worked just fine, however, when I tried to use the ubuntu/xenial64 box, I faced the same issue. A comment in this issue thread brought me to a solution, which seems to work out.
I changed the line
config.vm.network "private_network", ip: "192.168.33.10"
in the Vagrantfile to
config.vm.network "private_network", ip: "192.168.33.10", auto_config: false
Dohn Joe
  • 323
  • 14
The issue is due to the network interface naming convention in new Ubuntu versions. Your Vagrant VM failed to be provisioned, but you can still ssh to it (vagrant ssh). There you'll see that there is no interface named eth1 (you can use ifconfig -a or ip link). In my case, I see the interfaces enp0s3 and enp0s8.
As mentioned in issue 6871
... we need a way to detect the interfaces instead of having a static assignment...
... or convince ubuntu to change their cloud image.
At the moment, there is no clean solution.
jzer7
Actually, additionally to Maximes answer, you could change the GRUB commandline in your box until the new version is propagated.
Just go to /etc/default/grub and set the appropriate line to GRUB_CMDLINE_LINUX="net.ifnames=0 biosdevname=0" You have to change the /etc/network/interfacesto reflect the correct names (eth0...).
See the documentaion of in certdepot for more Info.
Snafu
