Apache is rendering PHP files as text after Ubuntu 16.04 upgrade.
Apache is installed and running. PHP7 is running. When I execute the following command I get the correct output:
php -r 'echo "\n\nYour PHP installation is working fine.\n\n\n";'
However when I access http://localhost/info.php or any other php file I get the file contents instead of the page.
Most of the help online is for older versions of both Ubuntu and PHP, so I' m not certain they are reliable or not.
UPDATE: Apache won't start after installing libapache2-mod-php7.0 and enabling php7.0. See output:
douglas@douglas-acer:~$ sudo service apache2 restart
douglas@douglas-acer:~$ sudo apt-get install libapache2-mod-php
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
libapache2-mod-php
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/2.960 B of archives.
After this operation, 15,4 kB of additional disk space will be used.
Selecting previously unselected package libapache2-mod-php.
(Reading database ... 263897 files and directories currently installed.)
Preparing to unpack .../libapache2-mod-php_1%3a7.0+35ubuntu6_all.deb ...
Unpacking libapache2-mod-php (1:7.0+35ubuntu6) ...
Setting up libapache2-mod-php (1:7.0+35ubuntu6) ...
douglas@douglas-acer:~$ sudo a2enmod php7.0
Considering conflict php5 for php7.0:
Enabling module php7.0.
To activate the new configuration, you need to run:
Job for apache2.service failed because the control process exited with error code. See "systemctl status apache2.service" and "journalctl -xe" for details.
douglas@douglas-acer:~$ sudo apt-get purge php5
Package 'php5' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
The output of systemctl status apache2.service :
● apache2.service - LSB: Apache2 web server
Loaded: loaded (/etc/init.d/apache2; bad; vendor preset: enabled)
Drop-In: /lib/systemd/system/apache2.service.d
└─apache2-systemd.conf
Active: failed (Result: exit-code) since Dom 2016-04-24 08:21:35 BRT; 14s ago
Docs: man:systemd-sysv-generator(8)
Process: 9216 ExecStart=/etc/init.d/apache2 start (code=exited, status=1/FAILURE)
Abr 24 08:21:35 douglas-acer apache2[9216]: * The apache2 configtest failed.
Abr 24 08:21:35 douglas-acer apache2[9216]: Output of config test was:
Abr 24 08:21:35 douglas-acer apache2[9216]: [Sun Apr 24 08:21:35.235583 2016] [:crit] [pid 9226:tid 140666367190912] Apache is running a threade
Abr 24 08:21:35 douglas-acer apache2[9216]: AH00013: Pre-configuration failed
Abr 24 08:21:35 douglas-acer apache2[9216]: Action 'configtest' failed.
Abr 24 08:21:35 douglas-acer apache2[9216]: The Apache error log may have more information.
Abr 24 08:21:35 douglas-acer systemd[1]: apache2.service: Control process exited, code=exited status=1
Abr 24 08:21:35 douglas-acer systemd[1]: Failed to start LSB: Apache2 web server.
Abr 24 08:21:35 douglas-acer systemd[1]: apache2.service: Unit entered failed state.
Abr 24 08:21:35 douglas-acer systemd[1]: apache2.service: Failed with result 'exit-code'.
The Output of journalctl -xe
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit apache2.service has finished shutting down.
Abr 24 08:37:59 douglas-acer systemd[1]: Starting LSB: Apache2 web server...
-- Subject: Unit apache2.service has begun start-up
-- Unit apache2.service has begun starting up.
Abr 24 08:37:59 douglas-acer apache2[10261]: * Starting Apache httpd web server apache2
Abr 24 08:37:59 douglas-acer apache2[10261]: * The apache2 configtest failed.
Abr 24 08:37:59 douglas-acer apache2[10261]: Output of config test was:
Abr 24 08:37:59 douglas-acer apache2[10261]: [Sun Apr 24 08:37:59.748900 2016] [:crit] [pid 10271:tid 139911432607616] Apache is running a threa
Abr 24 08:37:59 douglas-acer apache2[10261]: AH00013: Pre-configuration failed
Abr 24 08:37:59 douglas-acer apache2[10261]: Action 'configtest' failed.
Abr 24 08:37:59 douglas-acer apache2[10261]: The Apache error log may have more information.
Abr 24 08:37:59 douglas-acer systemd[1]: apache2.service: Control process exited, code=exited status=1
Abr 24 08:37:59 douglas-acer systemd[1]: Failed to start LSB: Apache2 web server.
-- Subject: Unit apache2.service has failed
-- Unit apache2.service has failed.
-- The result is failed.
Abr 24 08:37:59 douglas-acer systemd[1]: apache2.service: Unit entered failed state.
Abr 24 08:37:59 douglas-acer systemd[1]: apache2.service: Failed with result 'exit-code'.
Abr 24 08:37:59 douglas-acer sudo[10258]: pam_unix(sudo:session): session closed for user root
Abr 24 08:38:02 douglas-acer sudo[10276]: douglas : TTY=pts/18 ; PWD=/home/douglas ; USER=root ; COMMAND=/bin/journalctl -xe
Abr 24 08:38:02 douglas-acer sudo[10276]: pam_unix(sudo:session): session opened for user root by (uid=0)
Abr 24 08:38:38 douglas-acer sudo[10276]: pam_unix(sudo:session): session closed for user root
Abr 24 08:39:01 douglas-acer CRON[10297]: pam_unix(cron:session): session opened for user root by (uid=0)
Abr 24 08:39:01 douglas-acer CRON[10299]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean)
Abr 24 08:39:01 douglas-acer CRON[10297]: pam_unix(cron:session): session closed for user root
Abr 24 08:39:01 douglas-acer CRON[10298]: pam_unix(cron:session): session opened for user root by (uid=0)
Abr 24 08:39:01 douglas-acer CRON[10300]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && /usr/lib/php/sessionclean)
Abr 24 08:39:02 douglas-acer CRON[10298]: pam_unix(cron:session): session closed for user root
Abr 24 08:39:51 douglas-acer sudo[10122]: pam_unix(sudo:session): session closed for user root
Abr 24 08:39:53 douglas-acer sudo[10368]: douglas : TTY=pts/5 ; PWD=/home/douglas ; USER=root ; COMMAND=/bin/journalctl -xe
Abr 24 08:39:53 douglas-acer sudo[10368]: pam_unix(sudo:session): session opened for user root by (uid=0)
Regarding the error Apache is running a threaded MPM, but your PHP Module is not compiled to be threadsafe. You need to recompile PHP I did find some help in https://wiki.archlinux.org/index.php/Apache_HTTP_Server regarding this issue, however the file paths didn't match the ones in Ubuntu, so I didn't try to apply the recommended fix.
