It seem that Ubuntu 16.04 LTS supports the ZFS filesystem. But how do I use it? I'm sorry, I don't know very much about ZFS, but it sounds good. I want it.
Asked
Active
Viewed 3.3k times
22
First off, use ZFS only if you really want it. See the Use Cases to know if you really need ZFS.
ZFS is supported only in 64-bit Ubuntu 16.04 installs. To install it run:
sudo apt-get install zfsutils-linux
To learn more, you can see the reference on Ubuntu or this excellent documentation.
A good introduction can also be found here
Ron
- 20,938
As root in an Ubuntu 16.04.1 LTS this works:
apt update
apt install -y zfs
You are then done. You can check it is there by doing:
zfs list
you can then create a pool by doing:
zpool create -f zxavi /dev/sdb
or whatever disk you want to use; and after that:
zpool status
Boom, done!
Xavi Montero
- 385
Since I only have 1 reputation, I can neither upvote nor comment on Xavi's answer, which is the correct one. Things not to do include:
- Do not waste your time with
, all of that Wiki page is obsolete as far as Xenial is concerned;mountall - Do not install a package named
, or use theubuntu-zfsso-called "stable" ZFS PPA.
