So I've just performed a "clean" install of Ubuntu 16.04 LTS ("Xenial Xerus") on my son's Lenovo G50-45 to Ubuntu and as you can see here, I had problems in the past with Wi-Fi disappearing... Previously, I was able to solve this problem and this was the same thing I have tried under Ubuntu 16.04 LTS, however this time round, that solution did not work.
Any ideas?
Update 1: I have tried a "clean" install in both "UEFI mode" (with Secure Boot disabled via the UEFI setup), and also a second "clean" install with "Legacy Mode" enabled... The ethernet cable was connected both times between multiple restarts (i.e. the laptop had Internet access), however this laptop still has no Wi-Fi.
Update 2: Having performed a "clean" install, dkms status now shows nothing... With (using an ethernet cable) or without Internet access, nothing is shown except a new Terminal prompt (This is after I had to install dkms using sudo apt-get install dkms ).
Update 3: sudo lshw -C network displays:
  *-network
       description: Network controller
       product: QCA6164 802.11ac Wireless Network Adapter
       vendor: Qualcomm Atheros
       physical id: 0
       bus info: pci@0000:01:00.0
       version: 20
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: driver=ath10k_pci latency=0
       resources: irq:37 memory:f0800000-f09fffff
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: enp2s0
       version: 10
       serial: 50:7b:9d:45:9b:62
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168g-3_0.0.1 04/23/13 ip=10.0.0.22 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
       resources: irq:33 ioport:2000(size=256) memory:f0c04000-f0c04fff memory:f0c00000-f0c03fff
If I'm not mistaken, this means that Ubuntu 16.04 LTS can "see" the (integrated) wireless card... It just can't use it.
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1436940 is probably what you are looking for.
Proposed fix from this link (step 1 is unnecessary for 16.04):
2) Get rid of the firmware folder for this card that's included with Ubuntu:
sudo rm -r /lib/firmware/ath10k/QCA6174/
3) Download the latest firmware:
wget https://github.com/kvalo/ath10k-firmware/archive/master.zip
4) Unzip the downloaded file. Inside the ath10k-firmware-master folder is a folder named QCA6174. Copy the QCA6174 folder to /lib/firmware/ath10k:
unzip master.zip
sudo cp -r ath10k-firmware-master/QCA6174/ /lib/firmware/ath10k/
5) Rename two of the firmware files like so:
cd /lib/firmware/ath10k/QCA6174/hw2.1/
sudo mv firmware-5.bin_SW_RM.1.1.1-00157-QCARMSWPZ-1 firmware-5.bin
cd /lib/firmware/ath10k/QCA6174/hw3.0/
sudo mv firmware-4.bin_WLAN.RM.2.0-00180-QCARMSWPZ-1 firmware-4.bin
6) Reboot your computer. Run "lshw -C network" to see if your card is recognized. You can delete the files you downloaded earlier:
cd ~
rm master.zip
rm -r ath10k-firmware-master/
Verified to work on Ubuntu 16.04 LTS (with kernel 4.4.0-21-generic)
Last updated April 22, 2016
emk2203
  • 4,393
  • 26
  • 52
