I need to kill a process that contains myName in its description. Currently I'm doing:
ps -ax |grep myName
I see PID
kill -9 PID
How can I do the same with one command without entering the PID?
ps -ax |grep myName
I see PID
kill -9 PID
If myName is the name of the process/executable which you want to kill, you can use:
pkill myName
pkill by default sends the SIGTERM signal (signal 15). If you want the SIGKILL or signal 9, use:
pkill -9 myName
If myName is not the process name, or for example, is an argument to another (long) command, pkill (or pgrep) may not work as expected. So you need to use the -f option.
From man kill:
-f, --full
The pattern is normally only matched against the process name.
When -f is set, the full command line is used.
NOTES
The process name used for matching is limited to the 15 characters present
in the output of /proc/pid/stat. Use the -f option to match against the
complete command line, /proc/pid/cmdline.
So:
pkill -f myName
or
kill -9 $(pgrep -f myName)
With a command's name use:
pkill -9 myscript
If you are looking for a string in the command line:
kill -9 $(ps ax | grep myName | fgrep -v grep | awk '{ print $1 }')
I have to warn you: the above command can send a SIGKILL signal to more than one process.
There are two very neat commands pgrep and pkill that allow entering search term or part of the command name , and it will either provide the PID(s) of the process or (in case of pkill) kill that process.
$ pgrep -f firefox
23699
Running the same command with pkill and -f flag will close all the firefox windows.
The -f flag is needed specifically to search through the full command-line of a process.
With pkill and sending signal 9, you can kill process by name:
sudo pkill -9 myName
You could do a simple for loop over all the PID's associated with the specific process name, like this:
$ for i in $( ps ax | awk '/[m]yName/ {print $1}' ); do kill ${i}; done
This will kill all processes that contain the word: myName.
