I have tried different softwares for drawing using my touchscreen (e.g. Gimp or Krita). However, when I touch and drag (to draw a line) what happens is that only the mouse pointer moves from one place to the other, but as I was not "clicking" to draw.
I also cannot use some gestures such as zooming a picture.
I have installed Touchegg, but I'm not sure how to use it and if it can help me solve this problem.
cinico
  • 145
First install touchegg:
sudo apt-get install touchegg
Install the dependencies for the GUI tool (for TouchEgg) using this command
sudo apt-get install build-essential libqt4-dev libx11-6 libx11-dev
Download the GUI touchegg-gce from GitHub. Then:
  1. Change to the directory holding the .zip file.
  2. Issue the command unzip Touchegg-gce-master.zip to extract the file.
  3. Change into the Touchegg-gce-master folder.
  4. Issue the command qmake
  5. Issue the command make
  6. Copy the touchegg-gce file to /usr/bin
Source: How to Configure a Touchscreen on Linux
Under "Touchegg" it shows you how to configure the program, maybe this'll allow you to draw on your touchscreen. I am sorry I am unable to help further as I don't know much about this program.
wjandrea
  • 14,504
HelpMeee
  • 648
A workaround is to hold down the mouse button while drawing. This gives you the advantage of not clicking accidentally when bumping the screen for example.
Dev
  • 712
